Nokia 3110 Cellular Phone Logo
Posted on Aug 28, 2011
I need nokia's codea - Nokia 3110 Cellular Phone
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Aug 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
1531
Points
10
Whether it's asking for Network Unlock code or security/password unlock code ?It asks for security /password unlock code means get from service provider and Unlock it,it asks for Network Unlock code means get the Nokia 3110 Model Phone Network unlock code at here
Classicunlocking.com/nokia/rs17wp8/ and Unlock it,Follow the instructions below and enter the Unlock code step by step....
Nokia 3110 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia 3110 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 3110 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 3110 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3110.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3110 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3110 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 3110
Each Nokia 3110 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 3110 mobile phone using the form above.
2answers
Needed phone restricted code''nokia 2610 imei 356863/02/141875/2
You can get the unlock code from any online site providing unlock codes.
1998 mazda mpv just changed fuel pump but still can't hear it turn on checked fuses but can't figure it out......need help please
Under hood left ,., a gray box beside the relay box ,., tow sections
,., lower is 2 rows ,., second row jump between 3 & 5 ,., Leave the jumper there
start
If started ,., You have ,., code P1455 (fuel tank sensor) need to be replaced to clear the code
As long you changed the fuel pump ,., it's Okay to drive
Ahmed
I have a Motorola "smart
Hi
The possible four digit remote universal remote codes for Motorola TV are:
0020 0003 0093, 0055
Three digit codea are: 003/ 173
OK.
I am forgot securitu codea nokia 1202 imei 351960032456493
Ask your service provider to reset the security code. They may demand personal identification documents + phone bill which should list your name.
Sep 29, 2010 • Cell Phones
I need the codea for a 1991 honda accord station wagon stereo
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try
https://radio-navicode.honda.com/
if not then only available from a Main Honda Dealer or a Radio Decoding Service
1helpful
2answers
Have codea 12-19-30-41-52-91 f10-32 please help the car i have is a 1990 cad sedan de ville 4.5 engine
ECM Trouble Codes
12-Distributor signal fault
19-Fuel pump circuit fault (short)
30-Idle speed control (isc) motor rpm out of range
41-Camshaft position sensor (CMP) or circuit fault
52-Electric control module (ECM) reset
91-Park neutral position switch or coicuit fault
BCM Trouble Codes
10-Outside temperature sensor or circuit fault
32-Electronic control module (ECM) to Body control module (BCM) fault loss of communcation
Source: Haynes repair manual
203helpful
19answers
I only get one channel
You can buy a cheap remote control anywhere. This TV uses the same codea as FUNAI tv's
Security brack
how to brack my nokia 3110c security codea 3110c security code
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
