Dyson DC25 All Floors Bagless Upright Vacuum Logo
Posted on Aug 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Foot release pedal didn't work so I put the part which kept falling out back in place. It worked for some time but now it seems that there is this other part which is on a spring that fell out of place and now the ball doesn't turn ( it turns but it seems it gets stuck somewhere ). I have a photo of the part which keeps popping out but don't know where to upload. Thank you
Anonymous
Level 3:
  • Master 1,116 Answers
  • Posted on Aug 28, 2011
Anonymous
Master
Level 3:
Answers
1116
Questions
0
Helped
528050
Points
3536
Upload your photo at the bottom of this window, where it says "Pictures".
1 Related Answer
electrotech1
Veril Gillette
  • 1126 Answers
  • Posted on Aug 29, 2011
SOURCE: Foot release pedal didn't work so I put the
You can call this number M-F 8AM-8PM
SAT.8AM- 6PM toll free for surport (1-866-693-9766)
2answers
My Hoover WindTunnel brush engagement pedal's spring
We are Fixya, we aren't Hoover. You need to contact them direct or take it to a local Vacuum Cleaner repair shop.
There are parts schematics in this link. Parts 30 and 31.
https://www.google.com/search?q=hoover+uh30301+parts+schematic
2answers
2answers
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 • Vacuums
Dear sirs, I have a Dyson DC25 and a DC24 (small one),both very new. On both of them it seems to be very difficult to release the upright into using position using the red foot release bar to bring it...
Sorry to hear you're having difficulty with your Dyson cleaners. In both cases, you should be able to recline the cleaners easily into the vacuuming position by depressing the stabiliser pedal and lowering the handle. As you do this, the stabiliser should retract automatically.
If you're concerned that your cleaners don't seem to be doing this correctly, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
1helpful
2answers
Handle on dc28 has been hard to put back since new but now won't move at all. Stuck in upright potion.
You DO NOT have to take your machine to a "certified technician" to fix
this problem. Stand behind your machine, lean
over and look at the front: Right in the center of the slit between the
machine and the beater bar head, you will see a black tab. Simply slide a
thin, flat-head screwdriver down and magically the machine will
release. NOW: once it\'s released, simply examine the area where your
screwdriver JUST slid down...see the dirt and gunk? DON\'T follow the
MANY suggestions of adding lubricant "which only works for a short
while" (by their own admission) WIPE AWAY THE DIRT AND GUNK and voila!
YOU are now a "certified technician" and you didn\'t have to sit through
any technical school to get there! You go girl!!!!!!!
24helpful
2answers
Eureka model 4870DT plastic foot pedal for is broken
This a fairly frequent repair on the Eureka Smart Vac model 4870, so I decided to go ahead and take a few pictures of the handle release pedal repair, and walk you through this step by step. The model that I did the repair on is a slightly newer model, but other then maybe the color of the vacuum, or the color of the foot release pedal, the repair is identical. $40 is an awful lot of money to do this repair, after it's all done with you'll be very happy that you choose to post this repair on Fixya, rather then paying $40 for someone else to fix it.
What you'll need to complete this repair. The links contained in the parts are links to the parts on our website, GoVacuum if you don't already have the new pedal.
- Eureka Smart Vac Model 4870 Handle Release Pedal (colors may vary, but will fit ALL 4870 models) Eureka Part 70042-355N
- Eureka Smart Vac Model 4870 Handle Release Spring (Only needed if missing underneath of old pedal)
- Large Flat Head Screwdriver
- A small amount of elbow grease. :-)
Step 1. Remove the old handle release pedal from the base of the Eureka Smart Vac if it hasn't already fallen out of the base of the vacuum. Here's what the pedal looks like installed in the base:
The easiest way to remove the old pedal if it's still inside of the base of the machine, is to take a larger sized flat head screw driver, and put it up underneath of the pedal. With the screwdriver underneath of the pedal, pry upwards on the pedal until it pops off. This can take some pressure to get it out, don't put too much pressure on this part or it will crack the bottom housing. If the pedal won't come out from the bottom, you may also try putting the screwdriver in between the top housing (different colored plastic part in front of the pedal) and the pedal and try prying here. I find it the easiest to do when I put the screw driver underneath and pry upwards like this:
Step 2. Once you've removed the pedal from the base of the vacuum cleaner, make sure that the spring is still inside the base. The spring is a metal torsion part that pushes upwards on the pedal to keep it from always falling out of the vacuum cleaner. I have highlighted the spring in this picture in red:
Step 3. If the spring is still installed, you're now ok to put the new pedal on. You'll see on one side of the pedal that the notch that locks the machine in the upright position, as well as on the bottom part of the pedal that part of the pedal that connects into the lowest part of the base that has two little circular notches that protrude out. This part of the pedal goes on the side closest to the vacuum cleaner's upright body. There's really one way the pedal will go into the vacuum. Put the pedal over top of the metal spring, and push down on the pedal as far as it will go. I find that a few GENTLE hits with a hammer on the top of the pedal will gently slide the pedal into the correct part of the lower base:
Step 5. Test the pedal by stepping on it to make sure that the handle release when you're stepping on the pedal. Also make sure the vacuum will lay flat on the floor when you step on the pedal a second time. Now raise the handle into the upright position and make sure that the machine locks itself in the upright position. If yes, then you're all set! If it's not locking, then there may be a more serious problem of the lower base part being cracked, which will not allow the pedal to sit properly. If this is the case, please just reply to this repair, or start a new repair with that problem, and I'll be happy to show you how to fix this. If this repair was helpful to you, (it seems that it saved you $40!) please be so kind and rate my repair helpful by clicking on the 4 thumbs up icons in the top corner of the repair. I really do appreciate that. We do carry most every part for your vacuum on our website, please feel free to check out our site, Govacuum.com for all of your Eureka vacuuming needs!
Thank you,
Chris J.
GoVacuum
2helpful
2answers
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
2helpful
Kenmore 31913 Foot pedal release lever broken-need to replace
FixYa techs - thank you for your response but I solved the problems. It took me 2 hours of continual searching but I finally found the parts - listed under the tab sew machines of all things!? There is one pedal in stock and I called the service company and will pick that up and do it myself. I took that part off my vac and put it back on so know I can do it. I've been fixing stuff all my life and it just takes some logic - anyone can do it if they have a tool kit.
Pedal does not engage anymore
I have the same problem. You will need to replace the handle release pedal, part number 8174899, $7.99 plus tax & shipping. Check with Sears Parts. It's a single screw that holds it in place.
Jun 29, 2008 • Vacuums
2answers
Foot Pedal was knocked out of alignment
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
