Remove the battery from the motherboard and check that it has 3volts or above. if not then replace it. That will cure your pressing F1 to continue all the time. As for the restarts then you will need to turn off Automatically restart in the control panel,system section. To do this you will need to boot into safe mode. Tap the F8 while booting until you get a black screen with white type on it. Its first option is to boot into safe mode. hit enter on this screen and windows will start with no drivers loaded. the screen will appear very large. navigate to the control panel as mentioned above and untick "automatically restart". Ok that and reboot normally. now you will most probably get a blue screen of death. note the first stop code. it will appear something like 0x000000??. Its the last two digits that are the clue to why this is happening. Google the stop code and you will now know why this is happening and do something to stop the problem.
