You most likely have a problem with the Automatic Idle control circuit. I suspect the controller as the source of the problem but it can be the Rotary Solenoid (Servo) that is open. Try turning off the automatic idle control switch and see if the generator runs at normal speed. If it does then you can troubleshoot the solenoid by disconnecting the wires and applying battery power. Reverse the power connections on the battery and see if it drives the opposite way. Reverse them again and it should again drive in the opposite direction. If it moves... the problem is the most likely the controller. If you pass your model number I can pass you a sournce for parts.
I am guessing this is an S-10000 model at the moment.
Thanks,
Kelly
