Washing Machines Logo
Anonymous Posted on Aug 28, 2011
I have an f2 error code on my kenmore oasis washing machine model number 110.2803
  • Anonymous Aug 28, 2011
    it isnt an f02 it is f 2
Gere knutson
Level 3:
  • Washing Mach... Master 842 Answers
  • Posted on Aug 28, 2011
Gere knutson
Level 3:
Answers
842
Questions
Helped
218211
Points
2087
HI,
You have a extended drain problem. Most likely you drain pump is clogged and causing your unit to fault out after 8 minutes of attempting to drain.
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Read more:http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears / Kenmore Fault Codes#ixzz1WKO5b8KR
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
  • Gere knutson Aug 28, 2011
    Your unit didn't show a single digit fault code to this model, I still would check the drain pump at it has a filter inside it and clogs frequently. Located inside the access panel under the door. When draining the unit coins and other large item collect in it and cause the unit not to drain correctly or fast enough.
    I looked at the fault code listed for the particle model number you gave and this is where I would look to solve the problem you have. Also is only cost a little time to check. Normally the unit will drain out completely in about 45 seconds to a minute, any longer causes problems.
    I hope this helps
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Jan 13, 2008
SOURCE: F2 error code
Chia, this is not a good one, F2 is a keypad failure or interface mismatch. You can try a couple of things. 1. unplug the washer for a minute and see if the code returns. 2. Remove the consol to access the control board, three screws on the backside and the consol lifts up. On the right side you will see the main board. On the right side of the board, center harness will be the interface ribbon cable. Reseat it a couple of times. If this doesn't work, I believe you will have to replace the touchpad. Catriver.
Anonymous
  • 1776 Answers
  • Posted on Sep 01, 2009
SOURCE: Kenmore elite oasis F2 (and beeping _
This code indicates a pump issue. First, remove and clean the filter. Then you need to check out the pump. Take a flashlight and look into the suction port on the pump. Check the impeller for broken or missing blades and make sure that the impeller moves freely. If any blades are broken or missing or if it won't move freely, the pump will have to be replaced. Hopefully, it is just clogged, but no matter how diligent we are, some items like coins, tacks, pens/pencils, or other hard items make it into the washer and some can end up at the pump and can damage the impeller or clog up the pump. Hope this helped and best wishes.
kapishtech
raj somaiya
  • 2272 Answers
  • Posted on Jul 26, 2010
SOURCE: Kenmore Oasis Elite Top Loading Washer with an F2 error
The F02 error code indicates keypad/user interface failure. Most of the time, this is caused by a problem in the keypad/user interface. It can sometimes be caused by a failed control board.You could have an intermittent problem such as a stuck key or contact. As long as the F02 is not displayed, the washer should work normally. You can continue to use it when the F02 is not displayed. It is still safe to use the washer.
Sometimes this problem is caused by a loose wiring harness connection between the keypad/user interface control board and the machine control board.
The F2 error code on this washer indicates a stuck button on the user interface control board. The procedure for accessing the control boards on this washer is shown in the image below. I recommend unplugging the washerand checking the wire harness connection from the user interface control board to the machine control board. Try unplugging the connections and then plugging them back in a few times. Make sure that they are plugged in correctly and then reassemble and test the washer. If the F2 is still displayed, then the user interface control board will need to be replaced.
CLICK ON THIS LINK TO GET THE INSTRUCTIONS HOW TO REMOVE CONTROL BOARD:--
http://media.fotki.com/1_p,wfbgkftgqtgssggxgtqsskgwtqkq,vi/gdqwksfbdxggskbksbb/1/1303472/5961857/image8028img-or.gif
You can order a new user interface control board from the Sears PartsDirect website or from----------
www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Anonymous
  • 15935 Answers
  • Posted on Sep 27, 2010
SOURCE: I have a model 27096 top load kenmore elite oasis ...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Bruce Denton
  • 273 Answers
  • Posted on Nov 25, 2010
SOURCE: My Kenmore Elite Oasis HE
Greetings,
this washer has a lid switch problem...or possible main board failure, but lid does concentrate on the lid safety switch. If you remember when you open the lid it stops..well, its a safety feature and prevents tub from spinning with lid open...this one is more difficult to service if your not use to working on washers...try unplugging machine and leaving off for awhile...does the door lock? check switch for lid fault
What does f mean on my cabrio washer, just f
your not reading the error codes right, the F simply stands for fault then the other lights indicate a number code like f2 f4 or f5 etc Whirlpool Cabrio Washer Error Codes Repair Help Washing Machine Diagnostic Test Error Codes Cabrio Bravo Kenmore Oasis
Code F
These units have several very common error codes. the most common being error code F1. Oasis washer repair is simple. The link below has a video that explains how to replace the main control board on a Oasis washing machine.
Oasis Washing Machine Repair Video
http://www.appliancerepairlesson.com/
I have a model 27096 top load kenmore elite oasis he washing machine that keeps flashing code F2 and keeps turning itself on. Help
F2 error code
you are absolutely right.many users are facing the same problems like yours:-- The F02 error code indicates keypad/user interface failure. Most of the time, this is caused by a problem in the keypad/user interface. It can sometimes be caused by a failed control board.
1helpful
I have a kenmore oasis elite it beeps all the time and flashes F2
Code F2 means a stuck button. I removed the interface and lightly sprayed each with contact cleaner. So far this is working. The interface costs about $160 and contact cleaner, $10. Good luck.
1helpful
1helpful
F2 and beeping
The F2 error is the user control board gone south on you, a new board will fix the machine, as always do you own your home and does the insurance cover appliances?
Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Panel Beeping and F2 error code.
IT SOUNDS LIKE YOU GUYS HAVE A BAD KEYPAD/USER INTERFACE. LOOK IN THE SERVICE MANUAL FOR THIS TOPIC AND FOLLOW THE TEST:
ACTIVATION OF CONSOLE AND INDICATORS
DIAGNOSTIC TEST MODE
[email protected]
2helpful
F2 error code
Top Washing Machines Experts
john h
