Bosch Exxcel WFX 145S Front Load Washer Logo
Posted on Aug 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a bosch exxcel 1400 washing maching and the srum no longer spins. What is this problem and how can I fix it? and roughly how much will it cost?
john
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Bosch Expert 517 Answers
  • Posted on Jan 09, 2014
 john
Bosch Expert
Level 2:
Prodigy:
Answers
517
Questions
Helped
134296
Points
901
Change the motor brushes
5 Related Answers
petercj
  • Posted on Jun 11, 2008
SOURCE: bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
ufonixa
  • Posted on Jun 17, 2008
SOURCE: my bosch exxcel 1400 washing
After checking that the pump was working freely and water was being extracted by means of the pump, I then assumed it could be one of two faults faulty brushs or motor but still as washing machines can hold a charge of electricity capable of causing a fatality after being isolated I ordered the parts required by refering to the model no. and enr no. located behind the door and requested a competent person to fit them. The parts i ordered were brushes.
Anonymous
  • Posted on Jan 24, 2009
SOURCE: Bosch Exxcel 1200 Express Washing
I had the same problem- machiine not spinning and a few days later not turning at all. Display would go from 11min to 1min.
I did 2 things - 1) changed the brushes on the motor- cost £7.50 .
2) whilst working under the machine disconnected pipe from drum to pump and emptied it- found 2 coins in the bellows.
Anonymous
  • Posted on Sep 13, 2009
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Anonymous
  • Posted on Jul 21, 2010
SOURCE: USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is [email protected]
My bosch exxcel 1400 express will not spin
take out plug first check the motor carbon brusher are not worn
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
11helpful
Bosch exxcell 7 washing machine (1400) Power cut at home. Display now shows key symbol - 12 minutes 1200 spin speed Have tried unplugging. Controls will not reset
Hi hulley3,
Keep the Start Button Pressed in for 5 sec.
If it does not help, try keeping the Power button in for 5 sec.
Should reset Child Lock.
Regards :-)
* If you found this solution helpful, please rate it
5helpful
5helpful
3answers
1helpful
I keep getting error message F04 on my BOSCH exxcel 1400 express washing machine. What does this message mean and how can I fix it?
  1. Loose debris blockin pump - Clean drain pump on the bottom of the machine,
  2. Drainage pipe and or drainage hose blocked - I would like help on this as well.
Bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
