i have a elonex web book, i am getting full signal strenght, when selecting network to log onto, it asks for web key. i enter this but will not connect
Dear Friend.
your question:hi, i have a elonex web book, i am getting full signal strenght, when selecting network to log onto, it asks for web key. i enter this but will not connect.
A: its very simple.. u get full signal strength. whend u selectiong network to logonto. is asked for web key. u enter this but it will no connect...
go to configuration of your access point. go to wirless option and change your wirless user name...
then save . and come out form access point. then restart your pc.. after that u connect is will ok ...
Check the key carefully.
Also check your config carefully
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin)and password by default the password is 1234 unless it has already been changed
from the left-hand navigation menu of the router manager,select wireles set up>wireless settings
from the center screen,select your encrytion type from under the Security Options heading
if the wireless network passphrase is visible,review it and use it to log on devices onto your network.
If it is not visible you can change your wireless passphrase but changing your passphrase will cause you to lose your wireless connection
Connect your computer to the router using an Ethernet Cable before entering a new passphrase into the text box and clicking apply.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
From the center screen, select your encryption type from under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
