How to replace pelt plotter hp t790
Clean sheet feed sensor by clean cloth
then goto service menu in setup mode
click last option calibrate sensor
then again last option calibrate sheet feed sensor
then follow the steps
once calibration is done
you can feed sheet or roll
The printer hpt770 when the printer pulls paper paper does not measure by Sensor
Leading
cause of paper jams is debris/foreign objects that accidentally fell into the
paper feed area. Please follow steps below to fix the problem:
1. Remove
the sheets of paper from the feeder.
2. Grab a
flashlight and look inside the feeder for any debris or foreign objects.
3. If
you're willing and physically able, you may also turn the printer over. Any
debris should just freely roll out from the feeder.
4. If
feeder is clear, place the printer back on the table, open the printer cover
and remove the cartridges.
5. Check
the cartridge area for any obstructions/debris in the cartridge carrier's path
or the paper path.
6. If
cartridge area is clear, close the cover.
7. Rebrick
(pull out power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds).
8. When the
printer turns on, reinsert the cartridges and load some paper. Try to print
again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Leading
1. Remove
2. Grab a
3. If
4. If
5. Check
or the paper path.
6. If
7. Rebrick
8. When the
again.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
