It's possible that your pressure switch is bad. For that model it's Frigidaire OEM Part #134762010. It's about $40 on line.
This manufacturer-approved water level pressure switch (part number 134762010) is for washers.
Water level pressure switch 134762010 senses and controls the water level in the washer.
Unplug the washer and shut off the water supply before installing this part. Wear work gloves to protect your hands.
SOURCE: New Electrolux FL washer - will not fill with water
There are three main possibilities here. Firstly there may be a blockage that is stopping the water from flowing. Secondly there may be an item stuck in the pump chamber. Lastly the pump itself may be seized up. On machines that have their waste pipe connected under the kitchen sink it is always worth checking that the plumbing is not blocked with fat or lint at this junction. Check for kinking of the waste hose, this may of course release itself if you pull the machine forward. As for blockages and obstructions inside the machine itself it would be difficult to give any real guidance as there are so many models. If the pump is seized or defective the solution is nearly always the replacement of the whole pump.
SOURCE: My new electrolux front loader is not filling with
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
SOURCE: my front load Electrolux washer asks me "clean
You do not need to clean a drain pump. After you have washes so many loads of clothes, soap scum builds up in your tub and will shorten the life of your product. You just need to run it thru the "clean" cycle. You can use 1/2 cup of bleach and NO detergent or you can by a tub cleaner from most grocery stores or Walmart and use that. It'll just remove any soap scum and mineral build-up off your tub. It should be done each time you washer tells you to do it. Hope this helps. :)
I appreciate your post, friend!
Based off the information you have provided you still have water inside of the dispenser of your Electrolux washer. This is a normal operation of your washer. This is due to the siphoning action of your dispenser and washer. You may need to empty the dispenser every once in a while due to the water left inside of it. I hope this information is helpful. -Matt
Hello friend, thanks for your inquiry!
I see you are experiencing a water issue within your Electrolux washer. It sounds like it could be a problem with your water valve, drain pump, or control board. Since it could be any one of these underlying issues I would recommend having a professional come and diagnose your appliance properly. I hope this helps to some degree. -Matt
