Sir, I have one compaq c 700 lap top. Its sound system is not working after I formatted it. kindly guide me as to how I can be able to instal sound in the lap top.
Can you plz give me the insstaller of the C791TU for the audio, because after I formatted it, there's no sound coming from the speaker...
Hello Ranjeet,
We need the exact notebook model or serial number and product number of the notebook under discussion to provide you the exact audio driver. However try the following audio driver:
This model of Presario has an audio controller that supports the high definition audio. You need to have Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio installed on the computer before installing the audio driver.
Here is the link for the Microsoft Universal Audio Architecture driver that need to be installed before installing the audio driver:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
After installing the UAA driver reboot the notebook and install the audio driver from the following link:
Conexant CX20549-12 High Definition Audio driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35940.exe
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "AUDIO DEVICE ON HIGH DEFINATION BUS" or Conexant High defination audio entry and click Update driver.
3. Select "Not at this time", click on next and Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp35940 folder and the double click the (WinxP -> Thrifty10 -> CPL30A5a.inf file for Audio) Select the .inf file, click open and Continue with the onscreen instructions.
Updated drivers list:
http://www.techiesspot.com/index.php/top...
I have sound problam with audio sound?
No
sounds
Igultoi ngome. What is the SP number for audio driver of Compaq C700 (791TU). I formated the HDD and lost everything. Now I manage to get back all ecxept the sound driver. Please help.
no sound on my compaq presario700
no sound after formating
problem
dear i have i m ajay i have presario c700 notebook pc
after fomatting my audio driver is uninstalled.
no installer for audio
i need drivers for my soundless compaq laptop computer
which site can i download sound and graphics software?
i hace the same probleme
we have some problam
i have
I have a C772TU laptop of compaq presario. The mic is not detected and does not work. Please help
compaq presario c765tu
my compaq 700's sound is not working
If your computer is not working or is not giving out sound after you have formatted. it means that your drive audio or sound drivers are missing, when you format any computer wether is laptop or desktop you will use every drivers, including VGA, SOUND DRIVERS OR AUDIO DRIVERS, AND ETHERNATE DRIVERS.
VGA, are driver which maintaning resolution GUI grafic user interface. so if theres no such drives on your computer everything will appear in ladger.
ETHERNATE this is means is one of the drivers on your computer, which alow you to get axcess of internate on your computer it means you can be able to use your computer on the internate, if you format your computer youll loose of af this drivers.
SOUND DRIVERS OR AUDIO DRIVERS these are drivers which alow you to listen music on your computer and even watch movies, but if theres no those drivers you cant be able to listen any music.
this happen only if you format your computer and also virus the can attact those drivers in order not to work properly.
You can be able to get all of this divers on the internate but first you have to specified which type of computer your using and also your operation systeam O/P.
IF YOU DIDNOT UNDERSTAND WELL MY EMAIL IS [email protected]
my phone number is +255 755 789430.
but if hope you have understood me, im a technician in computers here in Tanzania
