Samsung LNT5265F 52 in. LCD HDTV Logo
Posted on Aug 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung 52 inch LNT5265F has clicking sounds when I turn TV on. It takes about 5 minutes for TV to finally turn on. When it does turn on, it has various spots on the screen. I have to turn it off and then back on to remove the spots. Tonight the power went off because of Hurricane Irene. When the power came back on, I am now unable to turn tv on without it turning off immediately. I need a repairman. Where can I find one? This TV cost me $4000 4 years ago. I need help!
Sean Kelly
Level 2:
  • Expert 37 Answers
  • Posted on Oct 16, 2011
Sean Kelly
Expert
Level 2:
Answers
37
Questions
Helped
7401
Points
102
This sounds similar to a known problem with bad capacitors in some Samsung TVs. Even though the TV is out of warranty, Samsung extend the repair period for affected TVs. Get your TV model and serial number off the back and then call Samsung at: 1-800-Samsung (1-800-726-7864).
Explain the problem and let them know that you have heard about similar problems and heard they were being repaired out of warranty. In my case, they sent a tech out and did the repair for free.
If for some reason they will not do it, the repair is quite simple for someone who can solder and you can find details here: http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
When turning Samsung LNT5285F it takes about 5 minutes to turn on and it turns on with dead pixles and have to turn it off and turn back on in order to fix it - what could be causing this problem?
You have 2, possibly 4 capacitors in the power supply that are bulged (bad) that need replaced. If you've ever done soldering or changed components like that then you will be able save a repair bill.crikett.jpg See the dome at the top of the caps bulging.
10helpful
When I turn on the TV it clicks 6 or 7 times before it finally comes on.
Contact Samsung customer support. They have had problems with bad capacitors in some of these units and depending on when it was built, they are offering a one-time accomodation for repair.
Samsung LCD TV
hi,
your lcd ip board (power board) capacitor had already exhusted.
got to replace the ip board.
Samsung lnt5265f clicks on and off 45 x or more then comes on seems to be a big problem please help..
sounds like a tv I had ,probably a bad power switch on the tv. its switching on and off w/ bad contacts.
Call for repair
Samsung LCD TV slow to start
Dont have a solution, my samsung 46 inch is doing same thing. Have you found a solution?
Samsung LNT5265F
I am having the exact same issue with an LG42LB5D... anyone have any thoughts?
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
