Make sure all the springs that go to the carb and govenor are in place. some of them are just used to keep the linkage tight so there isn't any play. Another possibility is that the mixture on the carb is not set right. If you have an adjustment for the mixture, you can try to adjust it. With the engine running and warmed up. Turn the main jet adjustment screw (usually located at the bottom of the bowl) in till the engine RPM's start to drop. Then back it out til the engine runs smooth again. I would back it out another 1/4 turn and try it there. They tend to run better if they are set a little on the rich side.
Another possibility is bad gas.
