Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
I have a ryobi ss26 weed eater i would like to know what kind of oil do i mix with the gas
  • 718 Answers
Two cycle oil you can purchase from ACE, Menards,Home Depot.... the list goes on. Good Luck...
Posted on Aug 27, 2011
SOURCE:
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Have a ryobi ss26 weed whacker and having a problem getting it started.. the instruction manual is missing and after priming the unit, moving it to full and trying to crank it, it will not hit and when it...
Sounds like you need a new spark plug and probably a new gas filter. To start the weed eater it is recommended to pump the primer bulb seven times and the choke full down. You can get the fuel filter out of the tank with a hooked wire. Good luck.
Aug 03, 2017 | Ryobi Gas Hedge Trimmer
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I cant figure out how to change the line on ryobi gas weed eater (SS26 model i believe).
Hello, W/D here.
I wrote this tip a while back to explain how to wind the line on a trimmer. It should be helpful.
http://www.fixya.com/support/r2827867-winding_line_trimmers
Best regards, --W/D--
May 21, 2011 | Sport & Outdoor - Others
I am looking for a Ryobi weed eater manual. Need to know how much oil to put in my weed eater. Can you give me an answer or where I can get a free manual. Thanks
You did not list which model Ryobi you have, however...
If your Ryobi has a silver or black shaft, then it is an older model and requires a 32:1 fuel mix. In the USA, that is 4 ounces of 2 cycle mix per gallon of gasoline. If your Ryobi has a yellow shaft, then it was made by HCP and uses a 50:1 mix or 2.6 ounces of 2 cycle mix per gallon.
Sep 23, 2010 | Garden
I guess he needs to know what kind of oil he needs also
you shouldn't need to mix oil with gas on a four cycle engine. this is for two strokes.
Aug 23, 2009 | Garden
Need to know how much oil to mix with gas for a 4 cycle ryobi weed eater
You only need to mix oil with gas when it is a 2 cycle engine. 4 cycle engines run on straight gas. Since you didn't post your model number, here is a site you can hopefully find your owners manual at. Hope this helps.
http://odref.com/pdf/Ryobi/
Aug 23, 2009 | Ryobi Garden
Do you use mixed gas for a ryobi weed eater??
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
May 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi gas blower model #ry08570 need gas and oil mix
try 40 to 1 ratio it should say on the blower if not check the ratio on the bottle of 2cycle oil it will tell you how much oil to add to a gallon of gas
Jan 09, 2009 | Poulan Weed Eater Electric Blower/Vacuum...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
738 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
lnbn1975
Dennis Tokarzewski
Level 1 Expert
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
