The screen on my 32' Sanyo television sometimes goes blue, while not affecting the sound of the show or video Im watching. The picture sometimes comes back in, sometimes not. I can hear all of the shows, but the picture is hidden under this blue screen. Any suggestions?
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Sirs:
have a sharp 27l-s300b,I change a tuner and turn on ,the picture tube blue,no audio,no picture ,only blue.
please help me
thank you
[email protected]
Go into to on-screen setup and turn "Video Noise Muting" off. It sounds like you are tuning into a noisy signal so the TV 'thinks' that there isn't anything on the current channel and makes the screen blue. Also, try to get video input from Composite/S-Video. - Video Noise Muting also 'blues' a noisy composite/S-Video signal.
SOURCE: sanyo television
That set is probably not ready for the dump yet. The buzzing sound could be the power supply going into shutdown because of a shorted secondary supply, usually a shorted horizontal output. A good tech should be able to fix that at a reasonable price.
SOURCE: Sanyo HT32744 Picture mostly green and blue
On mine I took the rear cabinet off, unseated the card mounted on the picture tube, applied a little dielectric grease on the connector on the card and reseated the card, removed, re-greased and reattached the card. I have had no problem with either my or mom's which I did the same to since! This is an easy fix that anyone can do. The hardest part is moving the TV and reassembling the rear cabinet. Do not pull the cabinet back out more than you have to, to ease the reassembly of it.
I have a Samsung TX-P1634. I get a steady blue pic with light horizontal lines. I have sound and can change channels, every channel is the same blue.. I cannot bring up the menu. I have unplugged and tried different source's of cable but it stays the same. Please help I love this TV.
[email protected]
sound like the same problem, on the back of the box it has sanyo ce32wn4-r-00. audio is fine, theres tv but looks like a blue sceen covering the image. tryed the suggestion but doesn't seem to work any other possible causes. tryed different connection scart, arieal and so on, no luck.
thanks
