when I try to sew the needle seems to hit in the wrong area when it comes down in the machine and the bobbin wont fill now toowhen I try to sew the needle seems to hit in the wrong area when it comes down in the machine and the bobbin wont fill now too
You can't post conmments that contain an email address.
Troubleshooting/Frequently Asked Questions
Please click on any question below to display the corresponding answer.
Basic Tips for All
Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
have you tried turning the bobbin the opposite way in the bobbin case? it's also possible that the sewing machine may need some type of adjustment, it would be a good idea to have it check at a sewing machine repair shop.
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
can i fix the timing myself?
