I have many questions that I have to ask before we get into the nit and grit.
When you say the phone is not working what do you mean?
*Does the battery not keep the phone charged?
*Does your phone not make calls anymore?
Please reply back to this thread in order to troubleshoot this further.
Have a great day!
SOURCE: Problem with Calls
if the phone is still under warranty go get a new one otherwise it sounds like a serious hardware problem!!!!
SOURCE: motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
SOURCE: Razr V3i charging problem
Hi V3 is very fragile and if you use the incompatible accessories, you can ruin their ports easily. One weak point of V3 Phone is the SIM card Port is not an opening flap like other GSM phone but using pin and spring Port style which is mean you have to push your SIM card in and use the SIM Card edge to push the pin down in order to contact with SIM metal area interface. But by pushing force is varied from users so too strong and too hurry will damage the pin. If one of the pins is damaged, when you slide the SIM card in, the contact is missing of one or two pins due to damaging of the pin cause the error message "Insert SIM". In this case, only way is needed to replace the SIM Board underneath. If you can do it yourself, please follow the instruction pictures below. If you are not sure and never do this before, I suggest you send the unit to Motorola Repair Center. Your SIM Card Board and charging port will need to be replaced. http://www.itsjustmerob.com/files/V3_Razr-repair.pdf This is a Full Motorola V3 Officially Service Manual and even the Motorola Repair Center also has this one. so copy this link and print it out. Around hundreds plus pages but can be your Guide which you cannot find anywhere else. I gave it to you free but I have purchased it before. Hope that you can get it fix. Other solution is looking V3 parts on sale a lot on Ebay and use them to replace part to your phone will be cheaper if your phone is no longer under warranty. If it is still under cover then send the unit to them and don't spend time and money to do it yourself. But if it is out of warranty and want to avoid costly repair then use the method in the manual I provided you and you will be able to get your phone fix. Good Luck
SOURCE: Phone says "charge complete" but then just dies
I took your suggestion and replaced the SIM card, but the difference is I managed to locked it in tightly. It worked.
Check your Sim in another phone to confirm , if there is no CLIP then the service provider has barred you and must get in touch. Also is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
