Pyramid - PS21KX  20 Amp Power Supply Car Audio Amplifier Logo
Posted on Aug 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the protection light for ? it says check manual when lihgt is lit.
DROPNDEAL
Level 3:
Top Expert:
  • Pyramid Master 2,931 Answers
  • Posted on Feb 10, 2018
DROPNDEAL
Pyramid Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
931093
Points
21770
That is exactly what the protection light is for.
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
My amp just stopped working one day almost new dont known why
DID YOU CHECK YOUR FUSES? Is there anything lighting up on it to see if it is in fact turning on? If it's lighting up and there is no protection lights lit up then check your speakers to make sure you didn't burn them up. If there is a protect LED lit then unhook your speakers and see if it stays lit or not. If it stays lit then check to make sure you're getting enough voltage at the amp connection, minimum of 11.0 volts is required just to get it to turn on. If it has under voltage and over voltage protection LEDs see if they're lit. If you do all of these things and are getting enogh voltage, your speakers are not burnt, your protection LEDs are lit no matter what then you need warranty repair that amp. If your speaker wires are shorted it will make your amp shut down also, but since you were using it for a day or so my bet is that you burnt up one of your speaker voice coils and it's internally shorted and that will cause your amp to shut down in protect mode. Otherwise you probably internally fried your amp by too low of voltage or not enough current (amperage) due to not large enough conductor (too small gauge wire) should be minimum of 8 Ga. for each amp, 2 amps will require 4 Ga, 3 or more will need 2 Ga, or 0 Ga. wiring to keep the voltage and current flow high enough to keep from damaging the amps. Good Luck!
The lihgt of my penal don"t come on wend I turn my lihgt
I don't know about that but I really want to know that.
2answers
Resetting fuel filter warning light on toyota 2kd
Change the diesel filer element.
Unplug the only connecter on filter housing.
Turn the ignition key to on position.
Go back and plug in the connector after more than five seconds.
The light should go off
The protection light is lit as stays lit and i have no sound coming out
if the protection light is on its an hardware failure
the protection unit will not let you power on the Amp
need to take to service
if you want to fix the amp let me know
[email protected]
Jack
The flipup lihgts will not go down on my 86 vette
hi, yeh it could be a dodgy relay or the motors for the headlamps could be in a circuit protected by a fuse. have a look at them and see what you find.
2helpful
Brake lihgts dont work i have haz turns running
check brake light switch, under dash on steering column where brake pedal meet
Hi I have Prius 2001 has warning light on and Engine check lihgt, and Hybrid lihgt on engine runing stop plese advice, Fred Moon E-mail:[email protected]
have the auto parts store hook up their code reader to your vehicle to pinpoint just where the problems are happening. There is normally not a charge to do this. Hope this helps. Leave feedback if it does to help others
Protection lihgt on
Was the "fault" light on when she popped? There is no reset I'm aware of...they have a bad circuit if overloaded...meaning run below 13.7V for more than a minute or two. Can only be fixed at an electronics repair shop...sorry
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
1helpful
3answers
My amp is on but the protection light stay's on!!
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
Top Pyramid Car Audio & Video Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
