SOURCE: Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
SOURCE: Sharp microwave runs when door closed
This is usually caused by either a bad door switch, a loose door switch mount, or sometimes a problem on the control panel.
I would suspect the door switch mount has a broken tab allowing the switch to swing down when the door is closed, not allowing it to really be activated.
Also, even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: faulty microwave function on the SHARP R-957 model (900watt)
This
is a problem in one of the damper-related components, most likely the
switch, but it may also be the motor or the damper door.
The
damper is a door inside that opens or closes depending on cooking mode.
If the controller senses that the door is not in the right position, it
will shut down the cook cycle.
Sharp models stop after
59 seconds.
See the attached sample
photo for a typical damper assembly.
Info on ordering Sharp
UK parts / spares is here.
We're
happy to help you with free advice and we'd appreciate your
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes
Failure
Code
Condition
Check/Repair
F1
Open sensor, will
occur below 190F of cavity temperature within 15 minutes after
starting convection, combination or roast cook
Check oven temperature
sensor for continuity. Replace if zero or infinite ohms
F2
Shorted thermal
sensor, will occur if a shorted thermal sensor is detected
continuously over 5 seconds on convection, combination or
roast cooking
Note: It will take a minimum of 5 minutes of convection run
time before F1 or F2 code will be displayed if the thermal
sensor is shorted or open.
F3
Shorted key panel
(touch pad), will occur if a shorted key panel is detected
continuously over 60 seconds
Replace key panel
(touch pad)
F4
Open humidity
sensor, will occur if humidity sensor is detected as being
open continuously over 5 seconds
Replace humidity
sensor
F5
Shorted humidity
shorted continuously over 5 seconds
Replace humidity
sensor
F6
Shorted temperature
probe, will occur if temperature probe is detected as shorted
Replace temperature
probe
ProbEe
Open temperature
probe, will occur if temperature probe is detected open, or
not plugged into the receptacle
If probe is plugged
in and "ProbE" is on display check continuity of the probe
with an ohm meter. If zero or infinite ohms, replace it
SOURCE: I need a manual for Emerson Microwave mwg9111sl
When replacing the bulb in an Emerson, Microwave. Model mwg9111sl. Can you replace the bulb or the socket and bulb?
