Question about LeapFrog Tag Reading System
The tag pen will work with books we already have down loaded but when i plug it into computer it acts like nothing happened. It wont let me put new books on or anything. It connected and then the leapfrog connect page had to update it updated now it wont connect. I already un installed the program and reinstalled and it is still not working.
SOURCE:
  • 100 Answers
SOURCE: Leapfrog tag will not recognise the book Cars Tractor Tipping
Hello
Please take a look at this link and go through the steps. http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1638&p_created=1208987240
Please let me know if this helps you out.
Thank you
Posted on May 03, 2010
Testimonial: "The problem was with the country settings on the audio - it seems that the book I had was from the UK and not US. Thank you for your help."
  • 366 Answers
SOURCE: hi what does error code #1096 fault detail null mean?
Thanks for using Fixia.
Please try below instructions if they help .
You will want to use the LeapFrog Connect Tag Fixing Tool to see if you can resolve the issue. The instructions for Mac, and PC are listed below:
PC instructions:
1. Begin with LeapFrog Connect closed
2. Click here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe for the download executable file.
3. A File Download box should pop up. Select "Run"
4. You will be prompted for a location to download the program to, you will see a message "Unzip to folder"
5. Click Browse and select your desktop as the location to save the folder
6. Click "Unzip"
7. This should create a folder on your desktop named "LeapFrogTagFixTool
8. On XP: Open the folder and double click on the TagFixTool to open
9. On Vista or Windows 7: Open the folder and right click on the TagFixTool and select "Run As Administrator"
10. Connect the Tag Reader or Tag Junior to the computer and turn it on
11. Click the button "Click once to fix your Tag Reader or Tag Junior"
12. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Mac instructions:
1. Download the LeapFrogTagFixTool.dmg and mount the image. File is located here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
2. Drag the FixIt application into your Applications folder.
3. Close the LeapFrog Connect application (if it is open.)
4. From the Applications folder, double-click the FixIt application file to open the LeapFrog Tag Repair Utility program.
5. Connect your Tag Reader or Tag Junior to the computer.
(Make sure your toy is powered on.)
6. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
7. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Note: Please be sure to be signed into your admin account and are connecting to a USB port directly on the computer, not a port on the keyboard or other hub.
Posted on Jul 02, 2010
SOURCE: How to change battery on leapfrog tag? Trying
In order to change the battery on the tag "reading pen" turn it over and there is what looks like a flat head screw head on the back of the tag, it should be white. Give that a quarter turn and the back should pop off, ours was kind of tough to get off but after the back comes off you can replace the 2 AAA batteries. I believe the "pen" has to be turned on to connect to the computer so this might fix your connection problem also.
Posted on Aug 29, 2010
Ironfist109
  • 3018 Answers
SOURCE: i have lost the cables
Regards, Tony
Posted on Jun 13, 2011
SOURCE: I'm using Windows 7 64-bit.
I am having the same problem, contacted Tag (who is only there during work hours which really does not help) they supplied me with an alt connect file. That did not work either. Have you found a solution yet?
Kat
Posted on Jun 21, 2011
I installed my leapfrog connect for my Tag reader. It says to plug in the Tag with the USB cable to the computer ( which i did) and turned it on. For some reason its not picking up so i cant go to the...
it depends on what Operating system your using, if xp then goto devices in the control panel and click on detect new devices, also check there if the usb drivers are installed, sometimes you have to install the software before plugin it in. if it's win7 then again click on devices and also check my computer when the usb is connected, and again install the software before plugin it in. best regards.
Oct 30, 2013 | LeapFrog Tag Reading System
The Save to Tag button on the leapfrog connact application does not do anything and so none of the audio will download from the library to the actual tag device
mine is doing the same thing. it's brand new. my daughter got it for christmas yesterday. i've even tried it on my husband's macbook. both our macbooks are up to date and her leap pad works. i'm about ready to take this stupid thing back to the store. it synced all the books except for her tangled book and will not sync again. i've even tried to restore back to factory settings and it won't even do that. i've deleted and reinstalled the leapfrog connect app 3 times. also seems that the stupid pen sucks down battery juice. i've put brand new lithium batteries in the pen and after 2 hours the pen is acting like it's dying and the only thing we've been doing is trying to sync it.
Dec 25, 2011 | LeapFrog Tag Reading System
I was trying to view my pics on my computer. i plugged the usb in the computer turned the camera on and nothing happened. then i unplugged the usb frm the computer with the camera turned on and now my...
remove batteries. try and turn camera on, of course it wont work without batteries but this may clear any capacitors.now fit new batteries or just refit the old if you know they are good. and try again, does it work now?
Nov 09, 2011 | Fuji Cameras
Pen comes on, and there's no problem with connecting and downloding but when I place the pen on the book nothing happens. It's no longer recognizing that it is touching the book
I have the same problem and am trying to get a hold of them for the problem to be fixed. They keep telling me to clean the lense, or re download the books. The laser light won't even turn on. I can listen to the books just fine!!
Jan 13, 2011 | LeapFrog Tag Reading System w/ Bundle
Leap frog tag pen won't work any longer.
You can purchase new one from amazon LeapTV Educational Active Video Gaming for Kids. I hope this was helpful. cheers
Mar 03, 2010 | LeapFrog Tag Reading System
Adding new books into the leapster TAG. I already
The one my kids had (a couple of years ago) could only hold 2 or 3 books at a time. Just limitations of the storage capacity.
Oct 03, 2017 | LeapFrog Tag Reading System w/ Bundle
I can download audio onto the tag (according to the computer it's all synched) but the audio is not able to be played on the tag. Downloaded 2 new stories - Princess Stories and Olivia. Olivia doesn't...
I experienced the same problem. The computer indicated that everything was synced and that the new story was on the pen. When clicking on the pen it would not announce the new story. I discovered that you have to actually press the pen tip on the story in the book and then it suddenly recognized the story on the pen. It could be a security measure to ensure that you have actually purchased the book prior to being able to use the story on the pen.
Apr 07, 2009 | LeapFrog Tag Reading System w/ Bundle
Wont turn on
poke a pen in the reset button on the bottom back of the player. same thing happened to me.
Jul 14, 2008 | Samsung YP-K3 MP3 Player
LeapFrog Tag Reading System Logo
206 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
