HP Photosmart C4280 Aio Printer Logo
Posted on Aug 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to install ink cartiges - HP Photosmart C4280 Aio Printer
Anonymous
Level 2:
Scholar:
  • Expert 112 Answers
  • Posted on Aug 27, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
112
Questions
0
Helped
27784
Points
363
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Hello, I have replaced the ink cartige with an kit refill ink, not with some original cartige. At first it worked, now it shows me that the Black cartige is empy even if if have made the refill. I do not...
all you have to do is to press and hold Resume button for more than 5 seconds, this procedure will by pass the ink level counter and your printer will work with no problem.
tip
How can you clear a cartige ink jam
you can clear a cartige ink problem if it is not printing by rubbing metal part of the cartige by a eraser aur by polishing it by hot water
tip
How can u use a original cartige for longer period of time
u can use a original cartige for longer period of time by just refilling it before low ink level of the cartige by doing this you can use a cartige for maximum no of time as original cartige is used for once but you can again use that cartige
3helpful
5answers
I got my ink cartridge refilled but it's still saying its empty, how do i get it to print anyway?
So as MUKHTAR states, do not refill cartiges when they are TOO EMPTY as most of the new printers have a sensor in the cartige that tells when it is empty. and when that sensor fills that the cartige is empty, it stays that way, no matter how much you refill it.
on the laser printers, when you refill your toner cartige there also is a chip that is changed (the sensor) because once that sensor feels that the cartige is empty you will not be able to use that cartige anymore.
EpsomStylusCX3650.
dear sir
it's a cartig problem may be yr cartig is SHORT it means it's circut is damage or not work so yr printer is not recognize that time yr printer understand that there is no cartig avalable so try to replace yr cartig it's help u
Thanks
Please vote
jo_chinmay
2answers
Ink cartridge problems
The printer is working again - I exchanged the ink cartridges yet again, and finally the printer accepted them. Still don't know why the problem developed.
Dell color cartridges
this sounds wierd to tell you
take out the cartige and if you can take out the cartige holders ( try to reach for the place where the ink flows out) spray it with a glass cleaning solution and let it pass inside where the ink pases and believe it or not it will clean properly the ink passages. try to clean the bottom of the cartige too.
some 1 trid it infront of me and it worked.
ps: an unproper positioning of the cartige will cause the printer not to work.
k24674
Grand Canyon Tech
Grand Canyon Tech
