Fuji Rod Repair Kit Logo
Posted on May 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I some how screwed up my camera. I was messing with the exposure compensation one night well i was out at a car racing event and i though that it said something about shutter speed on that button but once i started to take pictures after i've messed with it all pictures were coming up either completely black or dark as ever. How can i get all these settings for this back to normal? and then can you tell me how to change the shutter speed so that i can take some pictures at an event that is fast paced like a car race.
james laughton
Level 3:
  • Fuji Master 2,195 Answers
  • Posted on May 13, 2017
james laughton
Fuji Master
Level 3:
Answers
2195
Questions
Helped
411590
Points
6636
Unless you post the make and model of the camera in the comments below all we here can do is give you generic answers
like return the exposure compensation settings to zero
set the dial to shutter priority and set a fast speed but the faster the shutter the more light you need to get the correct exposure
so at night you need to use a very fast lens about F2.8 or better still F1.4 and a powerful flashgun to freeze the action along with an high ISO speed or learn to pan while shooting at least with a digital camera you won't be wasting lots of film getting the technique right
My canon powershot g12 lcd works fine but the photos are all 'whited' out
You may have the exposure compensation settings overexposing you images. Since it compensates without affecting the image prior to shooting, you won't see it until after the image is taken. Check that and the flash exposure compensation too.
Over exposed photos
Your exposure compensation might not be set correctly. Just behind and to the right of the on/off switch you will see a small button with a "+/-" symbol. That is the exposure compensation switch. When you press it, you will see a number displayed on the LCD. If the number is positive, that is your problem. Positive numbers increase exposure and negative numbers decrease exposure. Set the compensation to 0.0 by turning the rear thumbwheel while depressing the exposure compensation button.
What should exposure compensation be set on
That depends on what you're taking a picture of. Normally, you'd want it on zero.
Use it if the exposure meter produces an exposure too light or too dark for the subject. The camera's meter is designed to render all scenes as a medium gray. If you take a picture of a white dog playing in the snow, the camera will try to render the scene as a medium gray. In this situation you want to use positive exposure compensation to render the scene brighter.
Conversely, if take a picture of a black cat sunning itself on a black car, the camera will again try to render the scene as a medium gray. In this case you want negative exposure compensation to darken the scene.
I bought this canon rebel t2 film camera recently and used film with ASO 400. Portraits look ok. but the landscapes, especially the sky area look dark and grainy. I used ef 28-135mm usm lens. Any solutions...
That's odd that the pictures would be coming out under exposed unless the previous owner has gone into the camera functions and switched the ISO from auto to manual. Another reason is that the exposure compensation has been activated and set for - exposure
Under "normal" use the camera will read the DX code on the film canisters and adjust the ISO automatically. However the previous owner may have shut this off in preference to setting the ISO manually. Even though you have ISO 400 in the camera the ISO on in the camera setting may be ISO 1600.
Checking for the Auto ISO and exposure compensation is fairly easy as you can see the film canister through the film window or you know you have loaded 400 speed film. on the LCD panel at the back of the camera is an ISO icon and exposure compensation.
Make sure the ISO for the camera is the same as what you have loaded and if the exposure compensation is to the right of 0 then the resulting picture will be dark. Move this back to the Zero.
I wasn't able to find an exact manual (if you don't have one) for your camera but have found a camera with similar. Here is a ling for that manual.
http://www.butkus.org/chinon/canon/canon_eos_rebel_ti/canon_eos_rebel_ti.htm
Hope this was a help
Nikon FG Exposure Compensation Dial
try to set the itty ***** red dot to 0 again make sure the collar goes down its the compensation mode once its down try turning the speed dial again i haven't had a film camera for about 8yrs i had a nikon 6060 which is almost like a fg . hope this helps
Pictures too dark
Check your exposure compensation. It really sounds like someone set the camera to underexpose. This may be solved by removing the batteries for a few minutes. Other solutions are hitting the reset which will cancel all and return it to factory settings OR navigate to the exposure compensation settings and reset it there. If none of these solutions work, then the camera's internal program is messed up and its internal computer needs replaced.
2answers
Night pictures
a) Place the camera on a tripod (or a steady surface - e.g. a chair)
b) Select P mode
c) Focus and take the shot.
Most probably, with the above settings, the camera will select a longer exposure without flash, lighting the scene properly (i.e. making it appear as night, as it should be). However, know that this will also create motion blur of moving subjects (the kids, in this case). If you want to avoid this, you must use flash in slow sync mode. Press repeatedly the flash button, until you see the "slow" indication on the screen (where the flash info appears, down left). Again, the camera should be on a steady surface.
If your pictures are again too bright, it means that the Exposure compensation is for some reason set to +. Use the appropriate button (check the manual if you don't remember which one it is) to fix it
Exposure compensation problems
The exposure compensation stays where you leave it unless you do a full reset or a custom reset, and except when you're using scene modes. But you don't need to do a reset to cancel out an exposure compensation -- simply use the exposure compensation button to adjust the compensation back to 0.0EV.
Can I apply exposure compensation on the camera?
Yes, you can compensate for exposure in the range of +/- 5EV by selecting 1EV, 1/2EV or 1/3EV steps.
Top Fuji Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Fuji Sport and Outdoor - Other Expert? Answer questions, earn points and help others
