I need help on how to fix a sticking door on my microwave oven. Sometimes it does not open when the door release is pressed. Other times you press the release and it springs right open. How do I fix this problem?
Usually this is due to loosened mounts inside the oven. The mounts hold the door switches and grab the door hooks when it the door is closed. The solution is to realign and tighten the mount screws inside. It's less liekly, but it could be a weak or worn door open lever inside. I only advise people to work on a microwave if they're fully informed and aware of the deadly hazards and necessary precautions.
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. A good cleaning might also do it. A note to be on the safe side: don't spray any wd-40 into it, it can cause more problems and isn't likely to solve anything. Good luck
SOURCE: Microwave only works sometimes.
I coudl only find a Canadian support website.
http://www.emersonelectronics.ca/emerson/en/support/
Toll Free Customer Support: 1-800-663-5954
In U.S.A.
For all product purchased in the U.S., please contact:
Emerson Radio Corporation
9 Entin Road
P.O. Box 430
Parsippany, New Jersey 07054-0430
SOURCE: Emerson Microwave Oven Model MWG9115SL: At
I suggest you check and/or replace the door interlock switches.
Hopr this helps.
microwave oven door will not open
viking microwave oven door sticking
