Question about Acer 90.00012.30B Computer Speakers
I've set up my new desktop, plugged in the acer speakers to the back of the hard disk drive (green plug and USB) but no sound is coming out. (If I plug the audio cable into the monitor and hard disk drive, it works.) Is there are power cord for the speakers? Or are my speakers and/or USB cable faulty? Thanks, Annette
    Habit-Forming:
  • 35 Answers
The light green speaker audio cable should go to the light green connector on the back of your desktop not the disk drive or monitor!
Posted on Feb 22, 2019
Open SKy
  • 620 Answers
SOURCE: only one of my speakers work
Dognayr15
Happy Holidays
well, if you put the green cable on the green connector on your sound card, you,ll be fine, and see if work, fine, depending on your configuration speakers, 5.1 or 2 way, you can test if the sound go on the 2 speakers.you also check if something is bad with the other speakers
Posted on Dec 26, 2007
ComputerDave
  • 128 Answers
SOURCE: acer computer speakers
Speaker issue desktop's only
1. Plug USB into USB port (any)
2. Plug Black speak cable into LIGH GREEN (NOT BLACK) connector
3. You will see a popup window - make sure it is on Front Speaker out
4. Click OK - you will a cartoon computer with speakers on either side -then click on one of the
speakers to test
5. if that does not work then follow this:
Reinstalling apps:
1. If in Windows - Start - Programs - Acer Empowering Technology - Acer E-recovery management -
click on Restore at bottom then "Reinstall apps and drivers" - look for hardware drivers that you
need. Click "install now"
Posted on Feb 02, 2008
Chinthakaj
  • 416 Answers
SOURCE: Acer Travelmate 2480, speakers work when headphones in
Have you installed the correct sound driver?
Posted on Jul 03, 2009
graysand
  • 558 Answers
SOURCE: Acer Speakers not functioning
if you do have a reinstall disk you might want to disconnect the speakers ,run the install disk follow the instructions .This might take care of it.
Good luck
Posted on Aug 29, 2009
SOURCE: subwoofer won't work plugged into Acer laptop
i have an aspire acer 5735z laptop in the manuels it says its possible to have a video confrence,but when using msn messenger it says no webcam has been installed..how do i find or locate the webcam,if their is one at all?
Posted on Sep 01, 2009
Asus laptop with Win7 64 bit asks to format WD external drive while other laptops have no issue running it - how come?
you are not swapping from mAC to PC and back , right?
try other USB ports.
many external drives do not run with out an external power pack.
elements, use 4 diffr. 18watt power packs, Are you using the right one?
so plug that in ,first. then plug in USB , w7 must go Ding dong
or the USB is DEAD. (use this as #1 fact to follow)
then put ear to the case of drive, hear it spin?
if not ,there is no power, for SURE.
solve that first.
ok, it spins. (soft whirl\'g sound, do this when new to memorize how GOOD sounds)
for a tests, leave the USB cable , not connected.
let w7 boot to the desktop.
now plug in the USB HDD, cable.
W7 goes, Ding dong.
then see the USB icon in the tray, does it see the drive>?
Y/n?
click on that tray icon, i see USB to ATPI bridge then...
My externals (have many) shows as Z:/external below , bridge....
if not , USB is failing.
yes, ding dong, yes Icon, yes see drive above.!
then go to disk manager, type those 2 words in the run box.
start +run " disk manager"
CP(controlpanel)+computer management +disk management.
does disk manager see this spinning drive.
mine shows,. DISK 2 and is letter coded Z:
if not , the USB port is not working. or the drive is not with power.
if disk manager shows the drive, the assign a letter to said drive
now program manager can see the drive, with this letter Z.
it dont need to be Z , per ce\' but that letter is a nice flag.
step by step.
oops it has green tech, that means it goes to sleep.
make sure you turn that off first. or it may not show up at all.
it\'s so green its , invisible?
wd on their DL page has a spin down utility, use that.
Oct 03, 2013 | Western Digital Elements 2 TB USB 2.0...
Power goes on and off continuesly
Yeah, i think your HDD might be lifespan is nearing it end.
if you want to back up your data inside that HDD, assuming you gonna buy a new HDD soon, just give your current HDD to the seller and they will gladly extract whatever they can from it to your new HDD.
Jul 23, 2013 | Acer Aspire 5742 Notebook
Speakers stopped working
go to control panel then to sound, double check and see which of your audio components is set as primary output. it's possible that it has changed. if you go to device manager in control panel you can see what type of sound card you have installed. make sure it is set to primary. also if you have multiple audio jacks on the back of the machine make sure that you have the jack plugged into the green plug.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 05, 2012 | Acer Aspire AX3960U4102 PTSFF02027 Desktop...
What port on the back of the hard drive do I plug the durabrand uc280 USB powered speakers into?
Hi Missy
You don't plug the speakers into the hard drive.
You should have two cables or wires
a USB cable, which you want to plug into any open USB port. the USB cable will not plug into any port other than a USB port, so just find any open one.
The second wire should be a male 3.5mm stereo jack plug.
If you have a desktop computer, look on the back for a round green hole that the stereo jack will fit into. There may or may not be a symbol of headphones. You may not have a symbol or colored hole, in that case find the two or three holes that the plug will fit into, then turn on a program that should have sound, then plug the stereo plug into each of the holes until you hear sound. If you hear no sound no matter which hole, check to make sure you do not have the sound muted.
If you are using a laptop, look for the hole with the headphone symbol.
Hope this helps.
Jul 31, 2011 | Computers & Internet
I have a Buffalo hard drive 500 gb, it has just stopped working green light comes on and it sounds like it is fireing up but stops light stays green no autoplay through my laptop I have also tried on other...
The power-supply seems OK, since you can hear it spinning, and the lamps are lit.
So, either the USB-to-disk-drive interface has failed, or the disk-drive itself has failed.
Open the enclosure, and remove the disk-drive, and connect it as a "slave" disk-drive in some desktop computer, to see if it works, when you bypass that 'USB' interface.
Jun 08, 2011 | Buffalo Technology DriveStation HD-HC500U2...
How do I get the saved files from my GoFlex on my new computer
You should be able to just plug it in to USB and read them since the harddrive has aleady been set up and used. The new machine should read it just like it will read a thumb drive you've saved files on. This is one of the big reasons why people like these external drives :) You can take them with you and use on another computer.
May 28, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
I can't find how to plug my speaker to my computer. it's a set of only one speaker and it has an USB port, also a normal pointy connection. I've tried to plug them both everywhere but it doesn't seem to...
Hi there bud...Make sure you speakers calbe the Audio Jack (green labled) is connected into the green labled socket in your PC..also make sure you have audio drivers installed , and/or motherboard drivers ;)
Happy new year
Jan 11, 2010 | Acer (AV120) Computer Speakers
Connecting speakers to Computer
In most cases the woofer plugs into the speaker which contains the power adapter plug, the green plug goes into the PC's audio out (usually a green plug on the back of the unit). When the USB is plugged into the machine the OS should plug and play the new hardware and may ask you to insert a driver disc if applicable.
After the OS has identified the new hardware and installed it you should be able to test additional audio out plugs if you are unable to hear sound from your first choice (again, ideally the green plug). There should also be a line out plug which may work for your purposes also.
If you are still having issues please post the model of your speakers so that we may look them up...
Feb 25, 2009 | Dell Vostro 220 Desktop Computer
It's usually the green plug that you hook up speakers to. If you look closely at the sound card area of your computer, you will see little pictures telling you which one is for the mike, line in & speaker.
Feb 14, 2009 | Acer Aspire™ T180 PC Desktop
Acer computer
It sure sounds like to me that your sound properties got messed up some how, Go into your control panel and look up your sound card or sounds. Now once in you settings, You can set them the way you want to hear it, Or you can use the default setting, That would set it back to original factory settings and back to normal, It just sounds like someone changed the settings by accident, That should get your speakers back to normal, You will also notice that there a many settings in your audio properties that can change the way the system sounds thru the speakers. If that don't help the problem let me know we will get it right if you can 't get it.... thanks bear001
Jan 11, 2008 | Acer Aspire 5050-3242 Notebook
102 people viewed this question
Top Acer Audio Players & Recorders Experts
topcat7736
Level 1 Expert
 Mikey
Mikey
ray gallant
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
