Computers & Internet Logo
Posted on Aug 27, 2011
Manual for Printmaster 2012 Platinum - Computers & Internet
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Aug 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
1304
Points
21
You can access the manual within PrintMaster 2012. Once you open PrintMaster click "HELP" on the toolbar and select "User Guide". Provided you have Adobe loaded on your computer this should bring up a pdf version of the manual. Once it has opened you can choose to save the file to another location such as your desktop so it will be easier to find when you need it.
My printmaster platinum 2012 will not open.
Try re-installing software. For more detail on cause. Right click on My Computer > Manage > Event Viewer > Application and check errors / warnings based on source.
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
1helpful
Is there a patch to have Printmaster Platinum 17 work on Windows 7
There is no patch/update available from Broderbund, to make PrintMaster® Platinum 17 Full Version compatible Win7.
4helpful
Will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
Is there an instruction manual for Printmaster Platinum 2.0
Is there any PDF documents on the CD-ROM?
Is there a "help" function within the software?
2helpful
Is there a manual with the Printmaster 17?
you can download the manual from my website
http://tricia8765.fatcow.com/COMPUTERTRAINING%20MANUALS.htm
you will see it is around the fourth entry on the link
How can I obtain a user manual?
you can buy one in ebay for less $5. good luck
3helpful
Where can I acquire a manual for Printmaster Platinum version 18?
i couldnt locate one on the new but if you launch the program it will have a help feature under the list on the MENU bar on printmaster you might have to print it... or call Broderbund for a replacement ... you might even fine one on ebay ....
Grand Canyon Tech
Grand Canyon Tech
