The back of the unit has only one rca output for the subwoofer. ive tried pluging only one of the rca's in and used a 2 to 1 rca adaptor neither methods worked. fusion have been no help at all does anyone know how to wire this up
If I understand your post right, you have:
A couple of ideas:
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Yes that will work do to rcas to that one
then hook the amp up to
red power
black neg
remote to the back of the head unit remote wire
then try the rca in every slot of the amp
make sure there is power there
and there is settings in the unit like it willl say rear ,or sub pick sub and then sub contoll high low medium
Yes. connect the sub woofer alone and use that 2.1 speaker system to hear the audio out.
the other 2 speakers wil be connected to the woofer
try to click on the link i posted here above. i check it out again and it was not empty.
keep us updated
the solution space was empty i dont think namishka actually posted a solution
using the 2 to 1 rca adapter to the woofer alone produces no sound so with the other speakers connected to it wont make a difference and the woofers amp will be set on low pass filter so if it were to work only low end sounds would come out of the speakers
in most cases that would work but in this case we're running 3 amps. it should be possible to run both the sub and rear outputs aswell as the front.(in my car i run 4 amps,1 off the front o/p's 2off the rear o/p's and 1 off the sub o/p) this is the first unit ive seen to only hav 1 rca o/p for the sub
