SOURCE: reset Norstar M7310 System Administration password
This works, i just did it today!!
Press Feature 985
Press the 9 Key
Enter RESETSMPSWD (73738767793) using the dialpad
Press YES
Once you have RESET the password, it reverts to the default.
See Below
If your system uses 2 digit extensions use 120000
If your system uses 3 digit extensions use 1020000
If your system uses 4 digit extensions use 10020000
SOURCE: nORSTAR m7310
To Log Into System Programming:
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
Press: NEXT Display will read: "B. General Admin"
Press: SHOW Display will read: "1. Sys speed dial"
Press: NEXT Display will read: "2. Names"
Press the SHOW Display will read: "Set names"
Press: SHOW Display will read: "Show set:__"
Enter the extension number of which you wish to change the name Display will read: "<##:name>"
Press the CHANGE softkey
Using the dial pad spell out the name Ex: If you need the letter
K press the 5 key twice and then press # to confirm the letter.
Continue until the entire first name is spelled. (note: you are limited
to 7 characters)
Press: NEXT (if you fail to do this step, the name will not be saved!!!)
Press the RLS key
Hope this helps!
SOURCE: Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
SOURCE: NorStar ICS Caller ID Upgrade
Yes, this is correct. install the co card with cid and you should be fine.
Dan
SOURCE: How to change the prime telepone for a phone line
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key(bottom right arrow).
the display should say LINES
press the show key (top right arrow)
the display should say trunk/line use
display should say line type:public
press the next key (lower right arrow) til you see prime set
press the show button(top right arrow)
press the change key and enter in the new prime set extension
press the next key ( lower right arrow)
press the release key
