Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1.Press Setup.
2.Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3.Press the down arrow to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring tones.
4 Press OK.
If that does nothing and is exactly what you have already tried then I think its safe to say that the internal speaker is damaged and will need to be replaced unless you can live without it.
Regards,
Chris
i unplug my printer for an entire weekend and it's still having the problem!
