SOURCE: Zenith M52W56LCD blue spot in center of screen
It could be as simple as dust contamination in the LE or lcd chip. You need a clean room to work on this area of the unit and NOTHING you can do there would make that possible, short of spending a few thousand to build one. Before we added a clean room enviroment we simply pulled the LE and sent it in to PTS - who has one and reinstalled...
In your case take it to a qualified shop and you'll save yourself a lot of grief..
Bill
SOURCE: MY TV has a blue cloud on the left side
Blue lcd is burnt up.. Normally happens due to excess heat from poor ventilation or not changing the lamp at the required time.. Allways happens on the blue as blue light is the hottest wave length, and as the lamp burns, it shifts to that side. Nothing you can do but replace the lcd itself. From the image shown, looks like the unit uses sony lcds.. Sonys are well known for there burns.. No quick fix on this one.
SOURCE: blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
SOURCE: red ghost image or shadow
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
rate me
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
