SOURCE: Replacement Watch Band
I also have an Adidas watch, but cannot find a replacement.
Unfortunately, very unique for the contours around the body of the watch. Where can I find a replacement watchband?
SOURCE: stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
SOURCE: Watch band sizing
OK, I make an attempt:
I saw on other pictures on the web that the links have small holes at the side. There should be some links with arrows r another marking. These are usually the links that can be removed to shorten the strap.
If there is a small arrow on the link, it means that you can push out the pin inside the hole in the direction of the arrow. Then the link can be detached.
You can push it out with a blunt sewing needle (break off the tip).
Remove links on both sides of the watch when resizing it.
Hope that helps.
Critter
SOURCE: How do I remove watch band links from m Stainless
I've got a great article that helped me out with this same problem! I thought this article explained things pretty well. http://hubpages.com/hub/How-to-Size-a-Watch
