It depends on what type of data that is, there are files that can be read by a certain program such as .pdf file it can be read by adobe acrobat.
what is the file type you will need to find that out first to be able to determine what program to use to be able to read the file.
to find out the file type you can right click on the file then select properties check what is the file type then, you can google and search for a program that opens the file from your watch.
also if you watch has a disc that came with it possible that it may have a program that can help you read the file from it.
you menyioned it is in a USB stick try putting the file on your desktop see if it can be read by adobe reader, or right click on the file and select "open with" this will give you the option to select a program to read the file, try using notepad see if it will open in notepad most files will open in notepad if not then try opening the file with adobe or word.
it is not giving me an option of file type, garmin connect doesnt even see a device regardless of data on it it talk of file setting and types but there is no device/file appearing
and no option to right click anything and change settings etc.
