Question about Proton MM2701VT 27" TV
Every time i turn on my tv it goes off on me. i wanted to know why?
Alba tv flashing blue light tv turned itself off
If it turns off after a while that's a transistor going hot.
You need a technician to test it for you. If you want to do it yourself
let me know. Good luck.
http://www.tvrepair.localdomain.me
Jan 08, 2014 | Alba Televison & Video
Sony 52in. Rear Projection kp57hw40
Yeah, it can be fixed. Let me know when Tv goes to Off, how many times its Standby light blinks?
Aug 02, 2008 | Sony KP-57HW40 57" Rear Projection...
Eldft406 HD Digital LCD TV.Just got it and the sound goes in and out.
I have this same one and it shuts itself off at random, one time after only being on for 40 minutes. It started within 2 days of it being set up and it was maybe used for 6 hours total when it first shut off. The remote hardly works too. Other people have the same problems with this TV, read the reviews of it on Target\'s site. I got mine at Target so I have 90 days to return it and I\'m waiting until around the beginning of Feb. when HDTVs go on sale again. I suggest you just return it,. You can\'t even find it on the manufacturer\'s website.
Nov 29, 2012 | Element Electronics HD LCD TV ELDFT404-B
Tv screen goes black.
t-con board board failing or the cable needs reseating, meaning unplugging and putting back on a gain. t-con board is the one screwed to the back of the screen with a metal shield covering it.
Feb 01, 2018 | Televison & Video
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
Cineplus tv, loud popping sound, no picture? Warranty co. gone!
having a hard time turning on my Cineplus LC-32R25C
Cineplus 32” High Definition LCD Television...when i hit the power button..thered light on tv goes to yellow..as it it was in sleep mode..and i dont know wat to do to get it out of that state to turn it on..is there a sequense of buttons on the remote i gotta push to get it to work?
Sep 13, 2009 | Televison & Video
Tv turns off after being on for 1 minute.
I assume its Sony DLP TV and symptom shows it is new lamp time.
Let me know exact model number to help you more info.
May 11, 2009 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony projecting tv kp-57wv700
Based on service manual info, it cant blinks 7 times as per symptoms, please count again blinks. It can be 5 times.
If its 7 times blink, Horizontal Deflection stopped in this case. If you want to repair it at your own, please let me know to guide you further but it is necessary you should have knowledge of electronics.
Aug 18, 2008 | Sony KP-57WV600 57" Rear Projection...
TV don't want to turn on and just sits there and blinks 7 Sony FD Trinitron WDGA
If the led blinks 7 times it means, the high voltage has exceeded 33k and the unit goes immediately into safety shutdown. This defect is normally found in the power supply regulation and horizontal circuits.
I would suggest to have it repair instead of having the set ON the whole time.
In regards to fire hazards is very unlikely since the latest components are using a flame retardant(PBB and PBDE) chemicals to avoid flames.
Jan 24, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Proton MM2701VT 27" TV Logo
21 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
