Princess series model FN66011S The refrigerator does not change temp.it remains warm...freezer does freeze. Is this a fixable problem?
HI!!
The little fan inside the freezer is the one in charge of blowing cold air into the fridge area, the freezer control (thermostat), regulates how cold it should get, and the Refrigerator control regulates how much of this cold air goes to the fridge compartment. It is important to keep the door gasket clean at all times in order to have a good thight seal.
Check:
1.- That the freezer and fridge controls are set correctly, acording to manufacturers specs. (a common problem arises when by accident, the temp. controls are moved out of preset adjusment.
2.- That the fan is working and sounds strong, (If you keep the freezer door open for a couple of minutes, you should hear and see the motor kiking in.)
3.- Find the vent(s) in the fridge compartment and feel if cold air is coming thru when fan is working. If fan is working and blows no air, Take the freezer's back panel off, (4 hexhead screws) just enough to see inside and check if the evaporator (radiator looking component) is covered with ice, blocking the flow of air towards the fridge compartment, if it is, your defrost thermostat and-or timer are defective.
Your temp control for the fridge when you first start it, should be a bit higher than the one for the freezer. (the freezer should be in the low-middle range.) This control is nothing but a actuator for a door that controls the flow of air from the freezer. The bigger the number, the wider the door opens, and the colder the fridge gets.
Once the system is stable, let's say the next day, you can re-adjust your controls, (don't expect an inmediate change right away, change one digit a the time and check again next day) If you set your fridge too high and the freezer too low, the freezer may loose coldness and the problem would invert.
Good Luck!!!
