You may find some information here:
Singer Sewing Machine Company Serial Numbers
Hi geo.
try this link its all i could find it might help you out.
old singer fiddleback serial numbers are 4460938 524938 Would like to know...
SOURCE: don't know how to thread Pixie by Singer sewing
try this site, I copied the instructions, but could not get the picture. when you get to te site i put dpxie in and search, on page 11 is the picture of the threading,
from the thread spool bring thread to the left, under the plate and up through the ****, around the round flat disk, then down the front of the machine (looks like a split in the machine) thread goes in this and around the u-turn (picture of a line that looks like a u-turn) an back up the opening opposite the first one. bring thread through hole in the metal loop, bring thread back down to needle area. there may be one or two places to loop thread behind hooks to keep the thread straight then through the needle from the front to the back.
(in the needle area DO NOT WRAP the thread around the hooks, the thread should just rest behind them to keep the thread straight to the needle)
http://www.singerco.com/accessories/manuals.html
1. Set the Power Off/Speed Switch to the OFF position.
2. Raise the presser foot lifter.
3. Turn the handwheel counter-clockwise until the needle is in its highest position.
4. Set the thread spool on the spool pin.
5. Bring the thread under the thread guide slot at the top of the machine and then slip it into the tension disk (1). Pass the thread into the tension disk, making sure it slips into the disk securely.
6. Bring the thread down, go around the U-turn (2), then bring it back up.
7. Pass the thread through the eye of the take-up lever, from right to left (3).
8. Bring the thread back down and thread the guide which is just above and to the right of the needle(4).
9. Thread the needle from front to back (5).
SOURCE: What is the approximate value of a Singer sewing
http://www.singerco.com/support/serial_noletter.html
http://www.ismacs.net/singer_sewing_machine_company/singer_dating_by_serial_number.html
try these sites they may help you to put a value on your machine.
SOURCE: Hi, I have an old Singer sewing machine serial No
Unfortunately they are not worth a lot, there are thousands still about but people do think they are worth a lot of money, if you look on ebay you will see what I mean.
SOURCE: i HAVE AN OLD OLD OLD SINGER SEWING MACHINE AND
I can help you if you can email a picture, the serial number does not help I am afraid [email protected]
SOURCE: i have an old singer sewing machine. how/where can
model number should be below the stitch length lever
