Navman NavPix  N40i GPS Receiver Logo
Barbara Byfield Posted on Aug 26, 2011
The touchscreen has just stopped working. Is there anything to check or update to use as a fix?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Aug 13, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5956
Points
19
At the bottom of the N40i is a small switch with 1/0, switch it to 0 (off) position, before switching back to 1 (on) keep your finger pressed on the silver "on" button at the top of the unit and this will reset your Navman N40i
1helpful
My konka tv android is touchscreen but it won't work. I touch it many times but still didn't work.
There are a few potential reasons why the touchscreen on your Konka TV Android device might not be working properly. Here are a few things you can try to troubleshoot the issue:
  1. Restart the device: Sometimes, a simple restart can fix issues with the touchscreen. To do this, turn off the device and then turn it back on again.
  2. Check for updates: Make sure that you have the latest software updates installed on your device. Updating the software can sometimes fix issues with the touchscreen.
  3. Clean the screen: Dust and dirt can build up on the touchscreen and interfere with its operation. Try cleaning the screen with a soft, dry cloth to remove any debris.
  4. Check for hardware issues: If the touchscreen still isn't working after trying the above steps, there may be a hardware issue. In this case, you may need to have the device inspected by a technician or bring it to a service center for repair.
If you are still experiencing issues with the touchscreen on your Konka TV Android device after trying these steps, you may want to contact the manufacturer or a qualified technician for further assistance.
1helpful
I have a Fiat 500L mpw the touchscreen on the radio has suddenly stopped working
Go dealership there has to be update /recall or check for update on the link Uconnect at fiat website
My touch screen is all wonky its not responding to anything I'm trying to do with it and its doing things that I'm not doing it's basically made my phone useless at this point
Tf810c Touch screen wont work ' TabletPCReview.com - Tablet PC ...
forum.tabletpcreview.com > Forums > Windows Tablet PCs > Asus
Feb 24, 2013 - 10 posts - ‎4 authors
If it's greyed out, there is no data to reset, and it's not that causing the issue. ... wentall wonky, swipe for charms wont work, can select anything ... I tried the hard reset and low and behold my touchscreen started working again.
Nexus 7 (2013) erratic touchscreen & keyboard - Google Product Forums
productforums.google.com/d/topic/nexus/W0Hfkq8hf-c
GoogleJul 30, 2013 - I've used some touchscreen test apps and "ghost" touches would ... Myoriginal Nexus 7 (2012) didn't do this, nor did my Gnex or any of ... If it's software, I don't mind hanging onto it until a fix is released. ...... I can't believe no one has saidanything about the touchscreen not responding at all to touches I've ...
XPS 9530 touch screen stops responding (how to fix) - General ...
en.community.dell.com/support-forums/laptop/f/3518/t/19534511
Dell
Dec 1, 2013 - 15 posts - ‎7 authors
Dec 16, 2015 • Cell Phones
Touchscreen stopped working
1. turn off computer, wait 15 secs and then re-boot
2. Check for and install any Windows updates
3. Configure the touch display to identify your screen as a touch screen.
4. Search for and then select Tablet PC Settings from the results list.
This will vary with your model and Windows version. You are looking for SetUp of your touchscreen and Settings
Keurig B150 display screen quit working. Is there anything that I can do to fix this?
The display usually stops working if the water tank is overfilled. Sometimes just letting the display dry will fix the display. However other times if shorts out the display board and will not work. Then it is time for a new unit.
No signal how do I fix it
You have not said what model garmin nuvi ?
The touchscreen on a Garmin nuvi GPS usually loses sensitivity or stops responding if it's lost calibration.
This usually happens after prolonged usage.
Touchscreen problems are also caused by dirt, smudges and improper care.
If your Garmin nuvi's screen isn't performing as expected, Garmin provides solutions and tips to not only improve the device's performance, but prevent premature wear and tear.
Calibrating the Screen
If the Garmin nuvi's touchscreen isn't working, you need to calibrate the screen.
Calibration resets and repositions the screen for optimal performance without deleting saved settings.
Before calibrating the screen, press and hold the "Power" button to turn off the device.
Pressing and holding the "Power" button again for about 30 seconds automatically displays the calibration screen.
Pressing the dot on the white screen calibrates the touchscreen automatically.
Updating Software.
If The Garmin nuvi's touchscreen is still unresponsive, updating the device's firmware to the latest version can solve operating system problems that lead to touchscreen problems.
Before updating the device's firmware, connect the GPS to the computer using the USB cable. When the computer detects the GPS, the "AutoPlay" menu appears on the screen.
Tapping the arrow on the menu automatically opens the "myGarmin Agent" download page.
From there, follow the prompts to update your Garmin nuvi's software quickly and safely.
Cleaning. In some cases, the Garmin nuvi's touchscreen won't respond to touch if the screen is dirty. Touchscreens are sensitive to dirt and smudges that decrease sensitivity.
If the screen is dirty, cleaning it with a soft, clean, lint-free cloth improves performance.
If the screen is severely dirty, using water, isopropyl alcohol or eyeglass cleaner removes tough stains.
To avoid damaging the screen, apply liquid to a cloth instead of directly to the touchscreen before cleaning it.
Tips.
Refer to your Garmin nuvi's maintenance and storage information found on the device's manual prevents premature wear and tear.
If the screen stopped working after prolonged exposure to extreme temperatures or water, the device's hardware is most likely damaged.
In such a case, you need to contact Garmin for additional troubleshooting and possible repairs.
Attempting to disassemble and repair the GPS yourself only increases the risk of damaging the unit even further.
also it could be a battery problem if the nuvi is not getting power ?
May 08, 2013 • GPS
The touchscreen menu disappears but the remote still works but, you do not know what activity your doing because you can't see anything on the screen
Hi. Try updating the firmware on the remote to resolve this issue. There is a known issue with the screens of Harmony One remote, and flashing the firmware usually fixes it. To do this, log in to the Harmony software, click "Downloads" at the top of the screen and click "Firmware."
Regards,
D
1helpful
2answers
Xenon Touchscreen stopped working
There is no way. My touchscreen has stopped working several times and everytime fixes itself after a few hours. DO NOT let this phone ANYWHERE near moisture or water, the touch screen is very sensitive.
2answers
Touchscreen not working
You may be able to go the TomTom website and download the last update programming. If the problem is software this should fix it.
1helpful
3answers
Some where else in this site it said to hold the menu and map button while powering it on. I did that and it fixed my touchscreen problem, however I did loose all data, but I have that saved on my PC.
Top Navman GPS Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Mike Cairns
Mike Cairns
Are you a Navman GPS Expert? Answer questions, earn points and help others
