It appears that your auto defrosting system (if you have one) is not working. So your evaporator coil is frozen up - all that ice serves as an insulator and not enough cold air is getting down into frig section. Until you replace either the freezer defrost element or the defrost timer all you need to do is unplug for a few hours till it fully defrosts then plug back in - will work fine for a few days at normal internal temps till the ice builds up again.
If your timer and defrost element are both working properly, THEN, you might want to check if you have enough refrigerant in the system - you may have a leak.
2 ways for a motor to "Lock Up." Mechanically and electrically. If it spins free with the power off, it is electrically locked. Restaurant Parts and More in Ohio can help. Need Model and serial. Ask for Rick. 1-888-814-1110.
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost. There is also a switch which is placed for the door to close. Either one may be defective. Worst case is the freezer is not pulling down temperature wise.
Beverage air used R134a almost exclusively on refrigerators. The process is similiar to ac systems. You should weigh the charge in as per the data plate. Be precise as over or under charge can dramitically affect the performance of the unit. Hope this helps
Having to manually defrost an automatic defrost system tells me there is a problem with your defrost timer. Most Beverage-air freezers have a Paragon timer. There are two dials on these timers. An inner and outer dial. On the inner dial is an arrow to indicate the direction of rotation as counter clock wise. On the inner dial is a copper pointer indicating duration of the defrost cycle.
Observe the copper pointer, no movement indicates that the timer is bad.
