If you have nothing wrong with the laptop and it start up normally , do nothing
it may have moved to a notice that will go after a few seconds (10)and then proceed to normal start up
if it doesn.t then on pressing the start button hold down the delete key and eventually the bios menu ( start up menu) will come up on the screen
you van make changes to the start up procedures her but be very careful as any changes may get you into bigger trouble that what you have now
if you get the lap top running normally( not touching the bios settings ) press icon in the bottom lh of the task bar( flag in the world ) and that brings up the programs
at the bottom of that list is a search bar
type in chkdsk and then enter and puts the laptop into a check of the disk operation
that operation will find , fix and place the registars in all of the correct positions for all programs , files , folders , photos etc on the disc and will take up to 6 hours to complete if the disc is operating correctly
If you have a mechanical problem with the disc , you will get that message and the only fix is a new hard drive
SOURCE: HP DV5T-1100 Laptop Machine will not
hi which one of these is yours ?
FL772AV, FQ866AV, FL774AV, FL773AV
SOURCE: My HP Dv6-1030us will not boot up. It turns on,
Please Reinstall the OS from F11 Recovery Manager by continuously tapping the F11 Recovery Manager Key after pressing the Power Button to turn on the notebook and select advanced options and select system recovery and run the Back up up your data first and run the recovery to fix the issue
SOURCE: when I turn on my
possible cause would be the keyboard of your laptop. try to check your keyboard may their are some small particles that would cause the screen error.
SOURCE: At turn on it say ( Press the esc key for startup
When you turn on your computer, you do NOT have to enter the startup menu. Do not press any keys when it asks you to press the Esc key. Once that screen goes away, it will take a minute for Windows to boot up and your good to go.
Thanks for using FixYa.
