SOURCE: Not spinning, and buzzing sound
F02 is the code for long drain. The first thing to do is check the pump filter. Remove the lower panel by removing the 3 torq screws, the panel will come off. Right in front will be the pump filter. Remove the cap and pull the filter out. Clean out any lint and/or debris. See that you have some low basin to collect water, or some towels when the filter is opened. Or take the rear drain tube from the wall drain and lower it to basin or bucket. (The drain pipe must be fitted back in the SAME position) The spin will not work when your filter or pump is blocked.
SOURCE: Persistent F02 / SUD error. Tried all the tricks!
how about the line from pump to bottom of tank?not excess suds?might be bad control bd..f code is generated when control bd senses incorrect current draw by drain motor ..could be glitch in readings or a misread
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust? The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles. Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around. Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load. That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
SOURCE: What does the "sud" message mean?
hello fo2 means if the drain time exceeds 8 minutes the water valves are turned off and f/02 flashes. things to check / check the drain hose for any kinks and blockages check the electrical connection to the pump make sure the pump is running / check the drain pump filter make sure its not block if these do not sort the problem replace the pump. to clear the display press pause and cancel to clear good luck
shaun
SOURCE: SUD and F02
This error combination is commonly caused by a clog in the drain pump. The following link explains how to correct:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
If you have questions, please let me know. If the error codes do not clear after checking the drain pump, you may have a pump that has been damaged. If this is the case, it will have to be replaced. This additional link explains how to replace one:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
If you require a new pump, replacements can be purchased at searspartsdirect.com, appliancepartpros.com, repairclinic.com, or pcappliancerepair.com. All of these sites offere competitive pricing, so shop all of them for the best price. Use your model number as your search criteria. I hope you find this information helpful.
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if
the unit is unable to drain then after 4 minutes it will display suds and then
F02. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
other questions.
Kevin
Hello &
Welcome to FixYa
the unit is unable to drain then after 4 minutes it will display sud and then
other questions.
Kevin
other questions.
Kevin
