Good morning...my keuring coffee maker is six months old, and it has problems brewing a full cup of coffee, the hot water goes back into the cold water tank
Mine started to do that about a month ago. I would have to brew multiple "cups" just to fill one coffee cup. I ran several cycles of the largest cup, without any K-cups, to clean out the small metal spout. After about 3 hot-water cycles, it worked fine. I do this periodically, as I don't use the Keurig daily, so some of the residue builds up between uses.
3 beeps means plugged water line. Take off the bottom of the coffee maker with a small phillips head screwdriver. Use pliers (I used needle nose type) to remove the wire clamps holding on the silicone water tubes to the hot plate. In my case, the water line from the reservoir to the plate was clogged with something I couldn't see until I blew on the hose and it popped out, could have been scale, grounds etc Clean with vinegar. Back in service!
Check the needle inside the k-cup holder to ensure it isn't clogged. You can completely remove the k-cup holder and rinse it out using your kitchen sprayer to help loosen any debris stuck inside the needle. The needle is what punctures the k-cup and extracts the coffee from within the cup and can become clogged. Make sure when you replace the k-cup holder, that you align the arrows and snap the top or arrow-side in first. If simply rinsing your k-cup holder and needle don't do the trick, try inserting the end of a small paper clip into the needle to push out any remaining debris. This technique is actually recommended by the manufacturer, so it won't void any warranty or damage the needle. After replacing the k-cup holder back into the machine, try brewing a cup of coffee to see if it did the trick.
As a side-note, if you regularly use any "Hot Cocoa" k-cups, you need to make sure and immediately brew a cup of just hot water (no k-cup) to help clean it out and prevent the needles from clogging. The Hot Cocoa k-cups are notorious for clogging the needles up thus causing the problem you described above.
I found this solution on another post. Unfold a small metal paper clip and insert through the lower piercing needle of the cup holder to **** out any debris in the needle.Even a small piece of coffee or debris can slow the water flow through the cup.
Sometimes you have to do the decalcification two or three times. Then, monthly after that.
Cuisinart Coffeemaker Decalcification Process Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first. -Tha Mp3 Doctor
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
