Remove cover to the generator and remove the brush holder (if brush type) and any other parts bolted to rear. Remove wiring harness plug (most generators have an easy method to unplug all the wire from panel). Unbolt and remove the outer bell of generator leaving only the armature(use caution not to damage wiring, use camera to photo document the steps ). Remove the center bolt thru armature into crank. With piece of hardwood and large hammer, rap on one side of armature (metal part) then the other (careful not to miss the wood and damage the armature or wiring). The armature sits on tapered crank and will stick over time, may need to use penetrating oil. If your lucky, only takes a few hits on each side to break contact. Good luck
