There is a red and blue shadow in my picture and have tried to fix the convergance, but it shows my blue is alligned and the red just won't allign. Some of the allignment lines are actually slanted. No matter what I try I can't seem to line them up, I can't even get them close! What do I do?
i have a akai 55 inch rear projection tv , and the picture has bluish ghost like image on everything, its model #pt5598 hd, im being told its the convergance motor, and repairs would cost between 225 and 300 dollars, is this legit, or is it something i could fix myself ? thanks
I hav red and blue double images on the screen and the picture is very blurry akai pt5492s 54 inch projection
Hi I have the same tv with the same problem. Did you figure out the problem or solution?Hi I have the same tv with the same problem. Did you figure out the problem or solution?
You can't post conmments that contain an email address.
Ur tv have a problem known as a convergence picture problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows picture or 3D pictues look alike?Yes.The tv convergence board it dead have to be fix like replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the convergence board to solved tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Tv have a problems known as a convergence picture problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead.This tv convergence board must be repairs,u must require to replaced components parts like 2 STK convergence ICS and some or all of it resistors too.To fixed the the tv convergence board to solved the tv convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Your
convergence has failed and need to be repaired. Once quick test is to
goto your convergence menu and see if you can adjust red and blue. If
not its has failed and needs to be fixed.
You can get the parts and instructions from www.TvRepairKits.com
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Your tv is experiencing convergence problem. if you have tried the perfect focus adjustment from the menu and still not fixed, then the convergence ics need to be replaced. these ics converge the blue and red beams with the green to give a clear picture.
Hi I am having the same issue with the same tv. Did you ever figure it out?
