Computers & Internet Logo
Posted on Aug 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a toshiba satellite L10-103 How can i normally function USB ports on it so that i can use my globe prepaid broadband i use window 7 OS from now//......
  • Anonymous Aug 25, 2011
    I need more information, what type of device are you connecting to USB?
    Most, if not all have storage where a driver is kept and a program to install to access the functions of your device.
Anonymous
Level 2:
New Friend:
  • Expert 59 Answers
  • Posted on Aug 25, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
59
Questions
0
Helped
5757
Points
194
Your globe stick should work fine with any of those usb ports as long as you have installed that device to your pc.
OS Installion Issues
all you have to do is install the os on the new hard dis you are about to install by using it as an secondary hard disk the hard disk to usb cable is available cheap at the local computer service points or can be done without much problems on a desktop then mount it directly and boot from it
How we can connect to the internet using globe prepaid sim?
hi. use broadband modem or hand phone ( must support modem function )
TQ
2helpful
Dlink dir-142 Dodo usb prepaid dongle t12146l140 no connectivity optus usb prepaid dongle e169 responsive, no internet coverage connects with nintendo 3ds but no internet connection. windows xp...
plug the usb modem into usb slot of pc as normal.
Bridge the connection between the internet connection and ethernet router connection in network page.
Set router to ip add etc and it should share net access while pc is turned on atleast.
I do not have windows 7, so can I still use the avertv hybrid volar max tv tuner kit for windows on a regular computer?
YES!
You can use this on a regular computer with a usb port. The product says its works with Windows 7 and my question would be, You have 7 installed on the computer right?
AS long as it has a usb port it can be used on a PC, I hope you find this very helpful
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
1helpful
My prepaid broadband didn't work..it needs windows32 driver
If your Windows OS is 64 Bit you can,t use it as you said ,your broadband.But i bet your problem is other.Usually if your broadband is from a USB then a driver is needed to set up your connection.But if is a cable connection you don,t need any.Post more clear any error messages.
1helpful
How to install globe broadband-prepaid to a laptop?
please specify what type of prepaid broadband, is this USB tattoo stick? or 3g / WIMAX broadband?
  • For tattoo, you simply plug in the USB tattoo stick to your computer and it will install automatically
  • For 3G / Wimax, you simply plug modem into ethernet port using LAN cable
The usb ports don't work
Click Start
Right-mouse click My Computer
Click Properties
Click Hardware
Click Device Manager
Are your USB ports showing as "detected" (or "unknown device") and "enabled" ?
Did you install Windows from the CD-ROM set supplied by Toshiba? Windows XP? Vista? 7?
Usb port not functioning
Windows XP is not compatible with USB 2.0 ports. Could you confirm you have Service pack 2 or 3 installed. If not, you should install SP2, so they should work.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
