Question about Frigidaire Affinity AEQ6000WH Dryer
Error Code E68 on frigidaire affinity dryer. dryer will run about 2 minutes and then shut down with error code E68
    New Friend:
Can o still use the dryer with the E68 code
Or is there a risk of fire ?
Posted on May 30, 2016
SOURCE:
Jahn27
  • 1554 Answers
SOURCE: what does error code e68 mean
One of the buttons is stuck closed or shorted. Enter the function test mode and perform the button test to determine which button is stuck or shorted. When determined which button, try to free or unstuck the button then perform the test again. Replace the user interface board when the button is freed but the code still exists.
Press and hold the SELECT and CANCEL buttons simultaneously for 6 seconds to reset the control. When resetting is successful, the buzzer will sound and "rES" will be shown briefly in the display, and then immediately rotate the cycle selector knob 5 turns in the counterclockwise direction to the second position from the bottom.
Press and hold the OPTIONS and CANCEL buttons simultaneously for 2 seconds to enter test mode; the buzzer will sound 3 times and all of the LEDs will flash rapidly.
Rotate the cycle selector knob 4 times in the clockwise direction to enter button test. Press the buttons one at a time and observe the LEDs corresponding to that button light up. The LEDs should light up; otherwise the button is stuck.
Press and hold the SELECT and CANCEL buttons simultaneously for 6 seconds to exit test mode.
Posted on Apr 04, 2010
SOURCE: Frigidaire Affinity Front Load Electric Dryer
E68 indicates one of the panel buttons is stuck.
Posted on May 16, 2008
SOURCE: Frigidaire Affinity Dryer (model LEQ7000ES0)
right now i took the whole bottom apart from the main brain and so far is working good is not turning off now it may work on your too
Posted on Jun 22, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
Daniel S
  • 4323 Answers
SOURCE: frigidaire affinity E68. Error message E68. The
Hi
Error E68 means that one of the panel buttons is stuck, press all the buttons lightly and release. You can also take the control board apart and try to blow air with the help of hair dryer, doing all this should solve the issue. After this if the issue returns then you should replace the control. Hope this helps...please post back for further assistance.
Daniel
Posted on Nov 29, 2010
Need help my affinity dryer has the code E68 on it and the code Dr the model number is LGQ7000ES0
E68 is a stuck button error code... There is a diagnostic video for this on YouTube. You will have to get a new control board to fix the problem because the buttons are part of the board... Frigidaire Dryer Main Control Board 134557200
Jun 08, 2016 | Dryers
E68 ERROR CODE FRIGIDAIRE DRYER MODEL NO GLEQ2152EE0. CAN YOU DIRECT ME TO A SPECIFIC PART NUMBER?
E68 for this model number says in manual that this is for a "button stuck" or held down for more than 30 seconds
ck all your buttons for one that just doesn't "feel right" when its pressed , this one will be your problem
Oct 29, 2015 | Frigidaire Dryers
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire Dryers
I have a frigidaire affinity that is beeping with code E68 HELP???
Good Morning Friend,
I understand that your Frigidaire Affinity dryers is beeping and displaying an E68 code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Dryers
Why is my Frigidaire affinity showing code E68?
Good Morning Gary,
I understand you are receiving an E68 code on your Frigidaire Affinity washer, model# ATF7000E. The E68 code states that there is a current leak to the ground on the heater or there is a fuse open. This could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Affinity ATF7000E Front Load...
Error code e68
Good Afternoon Friend,
I understand you are receiving an E68 error code on your Frigidaire Affinity washer, model# ATF7000E. The E68 error code states that there is a possibility something is going on with the heating element inside your washer. It could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start your washer on the hottest cycle on a heavy soil level. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
Frigidaire Affinity Electric dryer E68 error. dries clothes fine, then error light comes on later- after dryer has been off. Will not start unless unplugged for period of time.
Sep 15, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity AEQ6000WH Dryer Logo
11,561 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
