Dictaphone 3740 Desktop Cassette Transcriber / Recorder Logo
Posted on Aug 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is no REC button How do I record with a dictaphone 3740?
Dictation Mall
Level 2:
  • Expert 145 Answers
  • Posted on Aug 26, 2011
Dictation Mall
Expert
Level 2:
Answers
145
Questions
0
Helped
54564
Points
173
To record, you need the optional microphone. Item 862300
Dictaphone intermittently shuts off while recording.
The power jack sometimes comes loose on this model. With the power on, wiggle the jack. If it powers off, then it needs to be resoldered. Service can be done by dictationmall if needed.
1helpful
I want to transfer files that were recorded on a dictaphone on to another dictaphone to play. How do I do this? The files are the same format and when I move them the dictaphone doesn't have them to play
Can't you simply take the tape from the 2750 and put it into the other Dictaphone to play it? Or is the other Dictaphone a different size tape (eg; mini or micro)?
1helpful
How to transfer voicemail onto cassette tape using Dictaphone 2750
Hello you will need and phone recor adaptor I recomend to used http://www.tvps.com/Products/1ECS-DUPR-Telephone-Record-Adapter---New__ECS-DUPR.aspx when your are ready just press and hold for 2 seconds telephone record button on your Dictaphone 2750 when your listen to your voicemail.
1helpful
How do i erase a tape on the Dictaphone 2740 transcriber?
Hello Just Press and Hold the erase button located on the bottom rigth then press rewind. All the rewind part will be erase.
1helpful
Tape stops
There is a switch on the right-hand side of the machine labelled 'VOX'. Set this switch to the 'OFF' position and you should be good to go.
'VOX' is voice-activated recording. It's designed to record only when someone is talking, and to pause when nothing is being said. In theory it's a great feature, but it never really works as good as you'd like. It'll usually miss the first few words you say, or it'll cut in & out while you're talking.
You can also set the 'VOX' sensitivity by adjusting the 'Tone/VOX' slider on the front of the machine.
Hope this helps...
I need to record something with Dictaphone 3750 - I have no manual and there is just a Tel. Rec button. Help
If you press and hold the 'Conf' button, the machine will record using it's built-in mic (located on the right-hand side of the machine, closer to the front). It is probably recommended to get a microphone that plugs into the machine for better recording quality. Depending on what you're recording, you could get a handheld microphone or a telephone record adapter that plugs into your phone and the back of the 3750 (press and hold 'Tel Rec' to use that).
2answers
Foot pedal won't work with hands free microphone
The 3750 won't let you control the telephone record jack. The only way you can get a mic to work using the Tel Rec jack is by pressing and holding the 'Tel Rec' button for about 1 second. But this isn't compatible with the hands-free operation.
If you're looking to do hands-free recording, it uses the built-in conference mic. Press and hold the 'Conf Rec' button for about a second and it should start recording. This built-in mic is located on the right-hand side of the machine near the front by the headset jack.
If you want to control the machine via a foot control while in Conference Record mode, you'll have to change the 'Foot Control Dictate' setting in the menu. Here's how:
1) Press and hold the 'Erase' & 'Search' buttons for about 5 seconds until the menu appears.
2) Scroll through the options until you get to 'Foot Control Dictate' and set this to 'Yes'.
3) Press 'Stop' to exit the menu.
4) Press the 'Conf Rec' button to enter record mode.
Now you should be able to control the start/stop of the record function via the foot control.
Hope this helps...
Telephone recording won't work
You need to have a telephone record adapter plugged into the back of the 3750. Then you press and hold the Tel Rec button until it begins recording.
Also check to see if the 'Vox' or 'VA' switch is on (voice activation). This will cause the machine to pause if the volume is too low.
Dictaphone 2740 desktop.
Try another cassette. There is a tab on each side of the back edge of a tape which when removed will prevent most machines from going into record. If the tab is there (and not bent in), then the switch at the back of the cassette compartment is dirty or out of adjustment. If you can find a manual for the 2740 (try at www.nuance.com, they bought Dictaphone), it will show how to change the Letter display back to a timeline. Good Luck.
Top Dictaphone Audio Players & Recorders Experts
NOEL
NOEL
diyfixtool phonefix
diyfixtool phonefix
Adviser101
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
