if only one game is not opening on ur phone then it might be not compactible but if all the games are not opening then you need to instal explore and hack ur phone ie.unlock the c:/bin drive
When you tried to reset or format your phone,your phone content such as calculator,wallpapers etc. will be erase. All you have to to is update the phone firmware using a Software .you also need a data.usb cable,full charge battery and a stable internet connection.
Here's how it works :
* First you need to download this software : NOKIA PC SUITE
* install the software and run it after
* turn ON the phone and plug the usb cable to your phone and thru the computer.
* Some driver will be installing,wait until it is recognized.
* Now follow step by step procedure until you need to start,be sure the above requirement follows.
* wait until the process is done and now check your phone,all content you are looking for is their.
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000 Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. OR: Reset factory setting with nokia flasher box. Thanks
Perform a full backup of your phone using nokia pc suite then restore this backup to your phone after the phone restarts you should have no more problems with the music player
