Televison & Video Logo
Posted on Sep 08, 2008
JVC HD-52Z575 projection tv...,picture dark...replaced bulb...no improvement...noticed glass in tv behind lamp is broke.
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
How do you reset the the lamp use time, after bulb replacement, on a JVC HD-52Z575 52inch Rear Projection HDTV
andycjavier,
See my tip at
http://www.fixya.com/TipsAndTricks/thanks.aspx?thid=8580883
Thanks for using FixYa and for the great rating.\
hardrocko
I need to replace the bulb and ballast in my jvc HD-52Z575 52 in rear projection hdtv-ready televvision. i need to know the part numbers and need to know where they are! I have no manual and would like to...
The parts diagram for the JVC HD-52Z575 is available here: https://www.searspartsdirect.com/model-number/HD-52Z575/1758/0333200.html . The lamp is part TS-CL110UAA. I don't see a separate ballast. If you look at the parts list for the cabinet, a Service manual is available.
I hope this helps.
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
3helpful
I just replace the bulb in my JVC HD-52Z575 everything was fine for about 10 days. Now when I turn the TV on it works for about 30 to 45 min before it shuts off, the fan kicks in, and the LED power light...
Ballast Board? it is what Powers Lamp, or CK Lamp Fan if it stops running and is not Keeping Lamp Cool
set is designed to shut off to Protect lamp from being burted up, you could have either Bad Ballast Board or Defective Lamp Fan,there is a few test you can do to see which Part is Bad.
Lamp and Power lights blinking fast and no picture...
hi mach500..We just had the same problem. Did you find out if it could be the fan?
Thanks
No picture.
The lamp is turned on by a high voltage ballast, very similar to the ones in your fluorsecent light fixtures. Your ballast is starting to fail. You should have your TV serviced by a JVC authorized service center because they have the training to deal with this issue. Waiting until it fails could very likely cause more servere damage especially if it fails shorted then the power supply will need to be replaced as well.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
