Humminbird 596 c Series Fish Finder () Logo
Posted on Aug 24, 2011
What size fuse to use when connecting a Humminbird 596c HD DI to the battery? Best regards John
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 10, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2208
Points
I put in a 3 amp fuse like recommended for these units and have had no problem. Either an auto fuse or glass fuse will work fine.
I HAVE A HUMMINBIRD 1158C DI WONT POWER UP TRIED TO CALL HUMMINBIRD SAID TO OLD FOR REPAIR CAN YOU HELP
If its too old to repair (humminbird is really great and well known for their repair shop!!). Time to invest in a NEW model. You will be GLAD you did.
How to connect Humminbird fish finder to Motorguide trolling motor
I would use slip rings to tie existing cable to prop motor support shaft and mount transducer to motor housing. 'slip ring'--metal ring a little bigger than shaft with a nipple the size of the cable. OR call the bird at 1-800-633-1468 or www.humminbird.com/Category/Company/Contact-Us/ and use some southern/country slang when talking. Best of luck 'you all'.
Will power up, but won't advance to menu
May require a software update.
register your unit at OnixSeries (this is a link to humminbird)
On your "My humminbird" page you will find free software updates for your particular unit.
download the latest update to an SD card and follow the instructions for the installation process.
Does the 561 need an inline fuse,and what size of fuse.
Best precaution is an in-line fuse of a Slow Blow 5 amp near the battery or power distribution terminal.
When i am going down the lake and hit a wave the systems goes off and I have to hit the power button to restart
Hi, check the power and earth connections to the unit. Also it will have a fuse on the positive wire, if it is a glass type fuse get rid of it and fit a blade fuse and holder. Hope this helps, regards Phil.
Humminbird 343c will power down on its own
Hi!
If the unit shuts off on its own, firstly check your power supply. I keep seeing customers running their ssounders from a small, portable battery configuration that doesn't put out the correct voltage...mostly seen with AA size batteries being rated at 1.2 or 1.3 volts (8 batteries times 1.2 volts is only 9.6 volts).
If the power supply is not the issue then I would say the internal power circuit is suspect...this can only be repaired by a competent repair person who knows how and what they are doing. If you open the unit up, you'll not only void the warranty, you run the risk of killing the entire unit from static shock.
Best of luck in your repair!
Mike
1helpful
Humminbird fishfinder keeps blowing 5v fuses .Power ok to base but as soon as you attach fishfinder fuse blows
Most probable component that has gone bad and capable of blowing the 5V fuse would be:
  • voltage regulator IV or transistor;
  • reverse protection diode;
  • zener diode;
  • shorted capacitor.
As the 5VDC normally supplies the logic circuitry, perhaps diagnosis and tests should be focused within that area.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Top Humminbird Boating Experts
Bill Eager
ADMIN Andrew
ADMIN Andrew
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
