Question about Panasonic RR-830 Desktop Cassette Transcriber / Recorder
I cannot get the foot pedal to work on the panasonic vsc transcriber. When I put th plug in all the way...the machine will not work. When i put it in half way, the transcriber will worrk manually but not with the foot pedal. Am I doing something wrong?
  • 145 Answers
With the foot pedal connected, you need to push the play button on the unit. Then the pedal will operate.
Posted on Aug 26, 2011
SOURCE:
Panasonic transcriber foot pedal rp-2692 not backspacing.
I would call service and see what they recommend, I have never seen the problem posted on this site, but I really doubt it will be just a small part the same as before..
Nov 16, 2016 | Panasonic Audio Players & Recorders
When using the foot pedal for forward playback to transcribe, when you lift your foot to stop the tape continues forward for about a second.
It sounds to me that you might have a mechanical problem in the machine. I am not familiar with this machine, but I have worked on lots of tape machines. The belts and rubber pieces can get slick or stretched causing problems.
Oct 24, 2017 | Sony M-2000 Microcassette Transcriber
During transcription, when you release the foot pedal, the tape automatically rewinds a little so you can resume easily. This no longer happens with my machine. I have tried several foot pedals, but the...
It could be the rewind solenoid is jamed up or there is a switch that comes loose under the tape deck. Either way, it will need to be serviced.
dictationmall
Nov 01, 2011 | Panasonic RR-830 Desktop Cassette...
Have a panasonic RR930 microcassette transcriber. Right now the foot pedal will not allow rewind though when I press the pedal I can hear it engage. I can, however, rewind right on the unit itself. ...
If neither rewind nor backspace work, the common problem would be that the solenoid grease has dried up and the solenoid is not retracting all the way. However, the track that the mechanism moves in also wears out, as well as the plastic rocker that depresses the rewind button where it engages the metal slide.
If backspace works but not rewind from the pedal then the problem is the pedal.
Mar 23, 2011 | Panasonic RR-930 Desktop Cassette...
My Panasonic RR-930 transcriber speeds up and slows down as I play back tapes. The problem seems to be with the machine itself and not the foot pedal or the tapes. Where do I start?
Start by cleaning the capstan roller. The rubber roller and small steel rod just above it, control the tape speed. Just a little lint, build up or animal hair wrapped around this can cause the speed to vary. Clean with alcohol and a Q-tip.
Feb 02, 2011 | Panasonic RR-930 Desktop Cassette...
Foot pedal does not work for my Dictaphone model 2750 Where can I purchase a replacement
Make sure the foot pedal is plugged into the SIDE of the machine and not the BACK of the machine. I've seen many people make this mistake...
Apr 30, 2010 | Dictaphone 2750 Desktop Cassette...
Transcription does not work .. foot pedal will not
Hello on the right side of unit is a switch for transcribe make sure is on the on position you are going to see on Deck A only lines on display, put your tape on Deck B is the only side that transcribes if the pedal does not respond you probably have a broken pedal here is one in a great price
http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
Or if you feel better to send unit to service try this.
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Nov 03, 2009 | Sony BM-147 Desktop Cassette Transcriber /...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Panasonic RR-830 only rewinds and fast-forwards, will not play
If the foot pedal is pluged in, press the play button and then you should be able to activate it with the pedal.
Jul 30, 2008 | Panasonic RR-830 Desktop Cassette...
Panasonic RR-830 Desktop Cassette Transcriber / Recorder Logo
157 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
