SOURCE: pavoni, no steam from steam wand
Unplug the machine. just unscrew the nut of the steam shaft. Take out the shaft by turning anti-clockwise the plastic knob until the whole shaft comes out. clean the inside of the attached shaft with a small wire brush. rinse under running water until water comes out the other end. try to straighten the bent shaft (one with the plastic knob) put it all back. The shaft that
SOURCE: saeco milk island - no froth
I agree with the poster that the key item is the little black plug (referred to as the valve in the supporting documentation). My milk island frothed beautifully for 2 months before gradually decreasing until I was getting just hot flat milk every time.
The valve has a dark grey pointed rubber plug which is possible to pull out and clean, and is fitted back in the hole by poking it back in. But what I found made a huge difference were the two slots/holes in the top of the valve piece. In my case they were clogged up (invisibly) with dried milk. As soon as I used a needle to unclog and clean the holes under a running tap, it got back to frothing again.
Whenever I use the milk island, I make sure I rinse and clean all parts immediately after use, leave them to dry, and before putting together again give the two holes in the valve a brief hard blow to clear it of water. The whole cycle takes about 30 seconds at most.
SOURCE: Cappucinatore won't pull milk through the tube
Hi
There should be a small pin on the top of the Cappuccinator. When it starts, twist the pin slowly until the milk flows up the tube. Then leave it where it is and it will work all the time.
SOURCE: How do I froth the milk using the Salton ex80 exspresso maker?
how to froth the milk for ex8
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
