For Philips/Norelco support, go here:
https://www.usa.philips.com/content/B2C/en_US/support-home/parts-and-accessories.html/
To see/get a charger, go here:
https://www.ebay.com/sch/i.html?_odkw=Norelco+1308&LH_PrefLoc=1&_sop=15&_armrs=1&_dmd=1&LH_BIN=1&_osacat=0&_ipg=100&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=4222+028+98250&_sacat=0
Good luck.
SOURCE: wiring a 3 prong neptune to a 4 prong new outlet
red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
SOURCE: Norelco Electric Razor problem: Jet Clean System won't work
You need to fill the based to the max solution line. There is not enough solution in the container.
SOURCE: wrong hdmi cord ?!
There is only one type of HDMI cable (as per the standard). Perhaps the cable you purchased was not "HDMI". "DisplayPort" cables are commonly mistaken for HDMI cables.
The male connector of a typical 6ft HDMI cable looks like this:
The picture below is a typical DisplayPort cable and can be differentiated from an HDMI cable by it's single angled corner:
SOURCE: Norelco Spectra 8 Model 8894XL: Need a new Razor Head Assembly
It sounds like you need a new "head holder". These often wear out over time and fall apart. You will find a replacement at shaveroutlet.com. See link below.
http://shaveroutlet.com/norelco-philips-spectra-sensotec-head-frame-with-hinge-p-329.html
SOURCE: i was shaving with a NORELCO #885RX and razor
i'll send yu a barely used on for $25 shipping if you would like.
dan
