Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
SOURCE: Can't transfer image to computer
Hi Set the camera mode to preview turn it off then connect USB to the camera and turn it on,no need to instal the canon software to get the pictures or video use microsoft scan and camera.The problem is not with the codec.If you want to use the camera software you have to read how to install it correctly.
SOURCE: Canon PowerShot A520 - trouble transferring pix from cam to cpu
Same problem here.
Very Annoying!!
SOURCE: I cannot seem to download the pictures I have
Use a card reader to download your pictures to a folder you create on your desktop.
SOURCE: downloading from camera...window
You probably can't. The best solution is to get a separate card reader and download to a folder you create on your desktop.
SOURCE: i have a Canon PowerShot
The problem I believe is the sequence or flow of the connection.
With the camera turned off. Connect the USB cable to a computer USB port and the other end to the camera digital port turn the camera on by using the "Playback" button here is a diagram
Place diagram here
You know there is an easier and better way of transferring picture files and that's by using a memory card reader. A memory card reader plugs into the USB port of a computer and the camera memory card is inserted into the reader slot. The computer then looks at this as an external Hard Drive. Both methods will need you to format the memory card after the images have been downloaded to the computer. Formatting the memory card in the camera in which it is to be used will clean the card and making it compatible with the camera both the camera and memory card can then communicate without errors.
